Side Mirror Pin Diagram
I am trying to find a pin diagram for the side mirror connections on a '03 X. I have found wiring diagrams with wire colors but the mirrors I purchased do not use the same wire colors. There are two more wires on the mirror side than on the vehicle side. This is for the 10(?) pin connector inside the door.
The mirrors are moving correctly and the turn signals work. There is no heat (which the mirror comes with) nor running lights (don't know about that function). I am assuming the extra wires are for the heat and possibly running light functions and would like to add those. |
Welcome to the forums.
See this thread. It's up in the tech folder. Several diagrams posted as well as the circuits. I only had to add one wire for the running lights. Did the OE mirrors have heat? 03 should have been a direct bolt on wiring wise IIRC https://www.ford-trucks.com/forums/1...l#post13176099 |
I actually had browsed through that thread but didn't see a diagram. But reading through it I found the running lights are pin # 7 but it doesn't say which pin is for heat.
So that was a bit of help but not complete. It did have the 10 wire connector but the new mirrors have more wires (assuming for the running lights and heat) and they do not use the same color wires. I am trying to identify the pins/wires for those two options. The original mirrors did not have heat. Actually I don't think I have the original mirrors as the wires were cut from the connector and spliced into the mirror wires. |
This might be helpful. It's the same colors on mirrors that do not have power fold.
Ford Truck Enthusiasts Forums - Curt's05's Album: mirrors - Picture |
This is what I had in my 01
Drivers Side 1A Mirror Wire ---------------Plugs from Existing factory Mirrors Red ------------Power Mirror--------------Red Blue ------------Power Mirror--------------Blue Yellow ------------Power Mirror--------------blue Light Green -----------Turn Signal--------------Green/White Black/White ------------Mirror Heat---------------Black/blue Black ------------Ground-------------------Black/yellow Brown ------------Running Light-------------NA Passenger Side 1A Mirror Wire--------------------- Plugs from Existing factory Mirrors Dark Green ------------Power Mirror--------------Darkgreen Purple ------------Power Mirror--------------Purple Yellow ------------Power Mirror--------------Black Light Green -----------Turn Signal---------------White/blue Black/White ------------Mirror Heat---------------Black/blue Black ------------Ground-------------------Black/yellow Brown ------------Running Light-------------NA |
