Side Mirror Pin Diagram - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 11-15-2013, 05:10 PM
Gene Horr Gene Horr is offline
Gene Horr has a very good reputation on FTE.Gene Horr has a very good reputation on FTE.Gene Horr has a very good reputation on FTE.
I am trying to find a pin diagram for the side mirror connections on a '03 X. I have found wiring diagrams with wire colors but the mirrors I purchased do not use the same wire colors. There are two more wires on the mirror side than on the vehicle side. This is for the 10(?) pin connector inside the door.
The mirrors are moving correctly and the turn signals work. There is no heat (which the mirror comes with) nor running lights (don't know about that function). I am assuming the extra wires are for the heat and possibly running light functions and would like to add those.
Old 11-15-2013, 09:39 PM
Archion's Avatar
Archion Archion is offline
Archion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputationArchion has a superb reputation
Welcome to the forums.
See this thread. It's up in the tech folder.
Several diagrams posted as well as the circuits. I only had to add one wire for the running lights. Did the OE mirrors have heat? 03 should have been a direct bolt on wiring wise IIRC
http://www.ford-trucks.com/forums/12...l#post13176099
Old 11-16-2013, 02:27 PM
I actually had browsed through that thread but didn't see a diagram. But reading through it I found the running lights are pin # 7 but it doesn't say which pin is for heat.
So that was a bit of help but not complete.
It did have the 10 wire connector but the new mirrors have more wires (assuming for the running lights and heat) and they do not use the same color wires. I am trying to identify the pins/wires for those two options.
The original mirrors did not have heat. Actually I don't think I have the original mirrors as the wires were cut from the connector and spliced into the mirror wires.
Old 11-16-2013, 04:39 PM
ExxWhy's Avatar
ExxWhy ExxWhy is offline
ExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputationExxWhy has a superb reputation
This might be helpful. It's the same colors on mirrors that do not have power fold.
Ford Truck Enthusiasts Forums - Curt's05's Album: mirrors - Picture
Old 11-16-2013, 10:29 PM
jspence105 jspence105 is online now
jspence105 has much to be proud ofjspence105 has much to be proud ofjspence105 has much to be proud ofjspence105 has much to be proud ofjspence105 has much to be proud ofjspence105 has much to be proud ofjspence105 has much to be proud ofjspence105 has much to be proud ofjspence105 has much to be proud ofjspence105 has much to be proud of
This is what I had in my 01
Drivers Side
1A Mirror Wire ---------------Plugs from Existing factory Mirrors
Red ------------Power Mirror--------------Red
Blue ------------Power Mirror--------------Blue
Yellow ------------Power Mirror--------------blue
Light Green -----------Turn Signal--------------Green/White
Black/White ------------Mirror Heat---------------Black/blue
Black ------------Ground-------------------Black/yellow
Brown ------------Running Light-------------NA
Passenger Side
1A Mirror Wire--------------------- Plugs from Existing factory Mirrors
Dark Green ------------Power Mirror--------------Darkgreen
Purple ------------Power Mirror--------------Purple
Yellow ------------Power Mirror--------------Black
Light Green -----------Turn Signal---------------White/blue
Help with wiring 08 towing mirrors in 03 Ex MoreBoostPlease Excursion - King of SUVs 14 08-29-2015 08:36 AM
Heat and lights on 08 mirrors JF0623 Excursion - King of SUVs 3 06-09-2015 12:27 PM
Another power mirror question sp5937 1999 to 2016 Super Duty 8 05-26-2014 11:46 PM
2010 super duty mirror questions Curt's05 Excursion - King of SUVs 1 12-05-2011 02:30 PM
Aftermarket tow mirrors for 2008+ the Goat 1999 to 2016 Super Duty 10 09-15-2009 02:18 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
