i'll have to check this weekend to get an accurate number, but it seemed there was still a good amount of travel
and luck would have it that one of the sleeves ended up running really close to the old bumpstop hole so i need to shift those over just slightly and weld a nut in from the bottom to attach them again since i've lost access to that section of frame after boxing it |
Correct me if I am wrong but the front springs looks like "dual flex" ? You mentioned super slides erlier?
apparently they're both, we got them from speedway motors and they have them labeled with both names, dual flex, super slides
these are the exact ones we're using Posies Super Slide Springs D152F 1948-52 Ford Pickup Drop Front Springs - Speedway Motors, America's Oldest Speed Shop |
little progress, painted the transmission and new alternator came in, I also placed a decent sized parts order last week mostly drivetrain stuff so that'll be coming along soon enough
http://i725.photobucket.com/albums/w...109_173142.jpg http://i725.photobucket.com/albums/w...109_173350.jpg |
Originally Posted by jimcar-9
(Post 13710384)
How much spring travel do you have left in the front? With the motor in? They are suppose to lower 3", right?
Looking good! i can see this settling slightly more with time and completed assembly of the rest of the truck if i find it bottoming out i can always shave the bumpstops a little |
nice progress, subscribed to thread.
Wow Thanks
Thatīs not a hole lot when you have the front clip left?? I googled and found this: Chevy 350 about 575 lbs th350 about 125 (short tail) My Y block is about 625 lbs my 3 speed with OD I dont have a clue on what the weight is, but I guess around 100 lbs. That wont give me a hole lot of spring travel on my truck????? |
So here's my version of fuel tank mounting, i had a plastic fuel cell left over from another project so I figured why not use it.
I didn't want to mount it under the bed and it's small enough to where it won't take up the inside of the bed too much and I don't really plan on hauling much if at all anyway. But I didn't want some out of place black plastic fuel cell just sitting in the bed, so I came up with the idea of finding an old wood trunk to place the cell in. I picked this one up off craigslist for $90, should look pretty cool I think. http://i725.photobucket.com/albums/w...q_600x450.jpeg |
What a great idea! The chest is very fitting as well. I like it. :-X22
i'm also going to do my own wood bed using old siding from a friends barn that's still in really good shape, so it should all flow together nicely
as promised, we have parts :-jammin
http://i725.photobucket.com/albums/w...115_183352.jpg http://i725.photobucket.com/albums/w...115_183515.jpg |
some weekend updates these are lug nuts i got off eBay, also started fabricating a seat mount for the bench seat im
going to use, it's out of an early '90s ranger and fits perfectly width wise just need to build up the height a little also painted the front calipers and assembled the rear brakes as well http://i725.photobucket.com/albums/w...117_161616.jpg |
have a couple new items...
bid and won an original 1948 owner's manual, thought it'd be a cool touch at car shows or just to have in the glovebox http://i725.photobucket.com/albums/w...mZ3g60_3-1.jpg also began work on the bed, i measured out and built a frame that im going to lay the wood planks in and set the whole thing in place as one unit once it's ready http://i725.photobucket.com/albums/w...125_103151.jpg http://i725.photobucket.com/albums/w...125_103126.jpg |
Sweet Project
Looking forward to the rest of your build! You do some great work!
thanks, i'm looking forward to it also
