Powertrain replacement advice needed
I've decided to replace the motor and tranny on my '59. Engine troubles have been frequent and the tranny needs a rebuild, so I decided to punt.
Anyone have suggestions about new power trains? I'm not looking for hot rod power. I'm only interested in having a dependable driver fir frequent use. |
I probably won't be much help here, but I installed a good running 69 302 cu.in engine, stock with a 2 bbl. carb, and its factory C-4 trans. I am retaining the stock 9" rear, but may change gears for a higher ratio. It is not running now, but it did run well in all aspects.
I was looking for reliability, and simplicity. I don't care much for the newer injected, computerized engines and trannys that many are installing these days. I have grown too old to adapt to the modern day technologies. Best of luck on your choices for replacement driveline. Aloha, Tony :-X06 |
I'm gonna do a 302 as soon as I gots some money. It will mate to my T5 nicely and parts are all over the place.
Nothing wrong with a '302!
