'71 F250 4X4 Power steering conversion complete
I finally did my power steering conversion on my '71 F250 4X4. It turned out awesome thanks to Glenn Davis. He proved me with some GREAT instructions on how he did his. Thanks Glenn. Let me know how your paint turns out on your Ford.
:D :p :cool: :D :p :cool: |
Super! :-X22 That's a nice looking truck Greg.
Hey Glenn or Greg, you wouldn't be interested in writing a tech article? Barry |
Barry, I will pass this onto Glenn. I think hes da man to have this opportunity. Greg
thanks guys, I will try and get a tech artical together and send it to the moderator- Greg that is one awsome looking highboy! My paint tured out stellar! Lime Green - Its getting a custom tribal flame job all along down the side - should be done next week. I will post pics as soon as I can.
Thanks guys. |
I sent the Tech Article to the moderator along with a drawing-
You can click on my gallery and see the pic if any one is interested. Cheers |
Greg, what yr. ps box did you end up using?
I used the pump and gear box out a 72 F250. I had to have hoses made for it because I have a 460 instead of the original FE engine. I also had to make up a pump bracket to fit the pump to my 460. If you still have the FE engine in your truck you can use the pump bracket off the donor. Glenn Davis is currently putting together a tech article on how to do this conversion. :-tap
BTW: I like the truck, can not wait to find one for myself.
Originally posted by heep70 I used the pump and gear box out a 72 F250. I had to have hoses made for it because I have a 460 instead of the original FE engine. I also had to make up a pump bracket to fit the pump to my 460. If you still have the FE engine in your truck you can use the pump bracket off the donor. Glenn Davis is currently putting together a tech article on how to do this conversion. :-tap |
Originally posted by comet Interesting, so the '72 box, was that a 2wd or 4wd unit used as a donor? I have a 2wd ps. unit I could use as a donor, but don't know if that's what you used. Seems the manual unit in my 4x4 is way too small to run fluid through and use as a conversion. |
Thanks Greg, that would be great if you could send it to me.
Just a FYI, I have already submitted Glenn's fine article to Ken and he said he will be adding it to the tech articles.
Barry |
Originally posted by comet Thanks Greg, that would be great if you could send it to me. |
I sent a you a message Greg. Thanks.
Has that tech article been posted, or can someone email the conversion info to me? Thanks! :-X22
