'71 F250 4X4 Power steering conversion complete - Ford Truck Enthusiasts Forums
Old 06-18-2003, 11:31 PM
heep70's Avatar
heep70 heep70 is offline
heep70 is starting off with a positive reputation.
I finally did my power steering conversion on my '71 F250 4X4. It turned out awesome thanks to Glenn Davis. He proved me with some GREAT instructions on how he did his. Thanks Glenn. Let me know how your paint turns out on your Ford.
Old 06-18-2003, 11:44 PM
BB's Avatar
BB BB is offline
BB is starting off with a positive reputation.
Super! That's a nice looking truck Greg.
Hey Glenn or Greg, you wouldn't be interested in writing a tech article?
Barry
Old 06-19-2003, 12:00 AM
heep70's Avatar
Barry, I will pass this onto Glenn. I think hes da man to have this opportunity. Greg
Old 06-19-2003, 09:07 AM
gdavis2265's Avatar
gdavis2265 gdavis2265 is offline
gdavis2265 is starting off with a positive reputation.
thanks guys, I will try and get a tech artical together and send it to the moderator- Greg that is one awsome looking highboy! My paint tured out stellar! Lime Green - Its getting a custom tribal flame job all along down the side - should be done next week. I will post pics as soon as I can.
Thanks guys.
Old 06-19-2003, 06:50 PM
gdavis2265's Avatar
I sent the Tech Article to the moderator along with a drawing-
You can click on my gallery and see the pic if any one is interested.
Cheers
Old 06-19-2003, 07:52 PM
comet's Avatar
comet comet is offline
comet is gaining momentum as a positive member of FTE.comet is gaining momentum as a positive member of FTE.
Greg, what yr. ps box did you end up using?
Old 06-19-2003, 11:29 PM
heep70's Avatar
I used the pump and gear box out a 72 F250. I had to have hoses made for it because I have a 460 instead of the original FE engine. I also had to make up a pump bracket to fit the pump to my 460. If you still have the FE engine in your truck you can use the pump bracket off the donor. Glenn Davis is currently putting together a tech article on how to do this conversion.
Old 06-20-2003, 09:56 AM
rebocardo rebocardo is offline
rebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud of
BTW: I like the truck, can not wait to find one for myself.
Old 06-20-2003, 01:30 PM
comet's Avatar
Quote:
Interesting, so the '72 box, was that a 2wd or 4wd unit used as a donor? I have a 2wd ps. unit I could use as a donor, but don't know if that's what you used. Seems the manual unit in my 4x4 is way too small to run fluid through and use as a conversion.
Old 07-01-2003, 12:56 AM
heep70's Avatar
Quote:
I used the pump, pitman arm, and gear box from a 72' F250 2 wheel drive. I can send you intructions that Glenn Davis has made up. I also have a few pics of my installation.
Old 07-01-2003, 01:36 PM
comet's Avatar
Thanks Greg, that would be great if you could send it to me.
Old 07-01-2003, 01:42 PM
BB's Avatar
BB BB is offline
Just a FYI, I have already submitted Glenn's fine article to Ken and he said he will be adding it to the tech articles.
Barry
Old 07-02-2003, 12:19 AM
heep70's Avatar
Comet, I need a way to send it to you. Email me.
Old 07-02-2003, 11:47 PM
comet's Avatar
I sent a you a message Greg. Thanks.
Old 07-13-2003, 06:19 PM
oppy's Avatar
oppy oppy is offline
oppy is starting off with a positive reputation.
Has that tech article been posted, or can someone email the conversion info to me? Thanks!
New to me 2004 F250: P/S Steering issue Calgary Glenn 1999 to 2016 Super Duty 2 04-22-2016 02:30 PM
Confused about oil drain valve... Glenn Jenne 6.7L Power Stroke Diesel 15 05-08-2015 09:38 PM
Where to buy manual steering pitman arm glenn Allen 1973 - 1979 F-100 & Larger F-Series Trucks 10 10-12-2008 09:49 AM
my new to me 46 tonner Glenn Mills 1947 and Older Ford Trucks 4 07-29-2007 07:35 PM
clutch pedal return spring glenn 79 1973 - 1979 F-100 & Larger F-Series Trucks 4 09-10-2005 11:07 PM
Tags
1972, 4x4, 68, 71, 76, arm, bronco, conversion, f250, f350, ford, pitman, power, powersteering, steering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
