Cab swap and Maryland MVA question
Has anyone done a cab swap or something similar in Maryland? I just got my tags for my truck this morning and asked the teller if there were any forms and she said that since there's a VIN on the motor and elsewhere, MD doesn't require any paperwork if the cab is swapped. Can anyone back this up for sure? I thought at one time I saw a form online for the MVA for custom vehicles, but can't find it on there. Thanks a lot.
It depends on the year. before 1980, the serial numbers were not always in the dash. Some were on the door, some were on the door jamb, some under the hood, some in the glove box
1981 brought great wisdom ( not really) Everything got a 16 digit serial number, starting with 1 for United states, 2 for Canada, and 3 for Mexico This plate was pop riveted to the inside dash metal, visible through the lower driver's side window The pop rivets are "special" and not available to the public In the state of Md, to change a cab after 1980, you must have the tittle for both cabs. You take the finished truck to Glen Burnaie MVA, and have it inspected. They then take both tittles, and submit you with a new serial number for the truck There is also a serial number on top of the frame rail passenger side front, and another on a cross member of the frame. I never found that one. Trucks manfactured after 2001, have serial number on the inside of every panel on the truck, including the door panels. The lady at MVA was incorrect about the serial number on the engine There is however a date stamp, with factory where built, and what line it came from This is true also for the transmission Front and rear drive axles have a tag, states year, gear ratio, truck plant and line it came from |
I did hear a few horror stories about the MVA and tearing guys truck in pieces looking for those numbers and others
they aren't very nice about taking stuff apart :( |
Originally Posted by jr32560
(Post 13546858)
Okay, sounds like a nightmare from what you guys are saying. But looking at the website, it seems all I need is the title for the truck (frame) and then a bill of sale for the cab. Have they changed the rules? I will call the MVA and make certain I don't need a title for the new cab, because I more than likely can't get it.
Originally Posted by dustybumpers
(Post 13546885)
& They don't put it back together....
there seems to be numbers in many hidden spots that they say they only know about :-huh |
Originally Posted by ericconn
(Post 13547218)
the destroyed a family members truck cab and other parts looking for serial numbers good luck any thing I can do to help hit me up-let the forum know how it turns out |
Having changed cabs, and gone through the process, I wish you luck.
I had to have a tittle for the cab AND the frame. |
Here's a post from another current thread. Not Maryland, but pretty much the same all over the US
Ford Truck Enthusiasts Forums - View Single Post - Junkyard find, how do I handle, advice please |
OK, so I just called the MVA just now, and got transferred to the state police safety inspection office in Glen Burnie.
According to the guy I spoke with, I need the title for the original truck and a bill of sale for the new cab (this is also in the language on the MVA website, quoted above). I don't necessarily need the "new" cab's title, which is good. He said they know where the VIN plate on the frame is, but I've been all over this truck and not seen another VIN plate. I'm really trying to finish up this truck, and now I at least know I can buy the cab at a JY and not have to buy a whole truck to get one with a title. I'd like to swap the cab before the end of the year. Thanks again for any advice. |
It's not a plate, but stamped numbers.
Look on the top of the passenger side frame rail right behind the shock bracket I'm glad they eased up a bit on the cab changes. It was a real pia before when you had to have both tittles. What do you do with the serial number in the cabs? |
Ok, thanks, I will look for those.
I'm not sure what happens to the old serial numbers. I don't know if they delete it or what. That's a good question. |
