shift lever removal
Anyone know how to get the shift lever off a 5 speed trans in an '89 F150 4x4?
There's a big nut on a threaded pin where the lever attaches to the trans. We've loosened the nut, but the pin won't turn or back out with mild use of a hammer(not ready to start wailing on it yet). Need the lever off so we can locate the new carpet on the floor before we cut holes in it. |
Try this link. Maybe it fits your question?
How to Remove the Floor Shifter Lever From My F150 | eHow |
It was almost that simple, just not that obvious. Lever has a tapered pin in it where it fits over the stub shaft coming out of the trans. Had to remove the lock nut from the tapered pin and put it on the threads on the other side of the lever and use the lock nut to remove the tapered pin. Also found that on Ehow.com. Believe that's the first time I've ever got a helpful answer from them.
Thanks. |
Here is a YouTube video showing the shift lever removal.
Thanks, we got it. WTF's wrong with a threaded shaft with a jam nut on it? Works on my Jeep.
Originally Posted by Old_Crow
(Post 13729189)
