shift lever removal - Ford Truck Enthusiasts Forums
Arkansas Chapter Join Chapter Leader: jimkidd
shift lever removal
Old 09-13-2013, 04:13 PM
Old_Crow's Avatar
Old_Crow Old_Crow is offline
Old_Crow is gaining momentum as a positive member of FTE.
shift lever removal
Anyone know how to get the shift lever off a 5 speed trans in an '89 F150 4x4?
There's a big nut on a threaded pin where the lever attaches to the trans. We've loosened the nut, but the pin won't turn or back out with mild use of a hammer(not ready to start wailing on it yet).
Need the lever off so we can locate the new carpet on the floor before we cut holes in it.
Old 09-16-2013, 04:35 AM
Calli's Avatar
Calli Calli is offline
Calli is starting off with a positive reputation.
Try this link. Maybe it fits your question?
How to Remove the Floor Shifter Lever From My F150 | eHow
Old 09-18-2013, 04:46 AM
Old_Crow's Avatar
It was almost that simple, just not that obvious. Lever has a tapered pin in it where it fits over the stub shaft coming out of the trans. Had to remove the lock nut from the tapered pin and put it on the threads on the other side of the lever and use the lock nut to remove the tapered pin. Also found that on Ehow.com. Believe that's the first time I've ever got a helpful answer from them.
Thanks.
Old 11-08-2013, 04:47 PM
LHO39 LHO39 is offline
LHO39 is starting off with a positive reputation.
Here is a YouTube video showing the shift lever removal.
Old 11-11-2013, 11:23 AM
Old_Crow's Avatar
Thanks, we got it. WTF's wrong with a threaded shaft with a jam nut on it? Works on my Jeep.
Old 11-12-2013, 12:20 PM
zhilton's Avatar
zhilton zhilton is offline
zhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to all
Quote:
Come on Walley, well all know "the Ford way is better". Don't believe me? Just ask some of those clowns in Dearborn and their questionable designs.
Column shifter pin saemetric 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 08-16-2015 07:48 PM
Shift Lever Removal Shadowrider123 1961 - 1966 F-100 & Larger F-Series Trucks 5 04-19-2015 09:57 AM
Shift lever pin 83 F150 ligito 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 12-09-2013 10:47 PM
Shift Lever Cap Steve Aerostar Aerostar 3 12-06-2013 10:10 PM
overdrive button on shift lever jerwiltho 1987 - 1996 F150 & Larger F-Series Trucks 4 11-27-2013 11:44 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
