Plow on EcoBoost
Can you put a plow on a 150 with the EcoBoost motor.
Originally Posted by coonman111
(Post 13497711)
Thank you.
I don't know coonman. I've seen lots of people put plows on trucks that aren't rated for it, and the steering system is still rated for the full max GAWR which depending on configuration may support a small plow.
I wouldn't put a plow on a half-ton truck, but if you want to I wouldn't let the steering stop you. What does the steering gear care whether you have a plow or not as long as you stay under your front GAWR? |
Just did some searching around, and there are people who have put plows on their EB trucks. Do some reading at Plowsite.com.
http://www.plowsite.com/showthread.php?t=136136 One plow outfitter mentions putting them on more than a few EB trucks without issue. |
Originally Posted by Crazy001
(Post 13501013)
http://www.plowsite.com/showthread.php?t=136136 One plow outfitter mentions putting them on more than a few EB trucks without issue. If Ford sees that a plow was mounted to a truck with no plow prep package, warranty claims could be denied. But hey, not my truck. |
I would think that the plow would restrict air flow to the inter cooler?
Originally Posted by RISUPERCREWMAN
(Post 13812668)
(Post 13812668)
Originally Posted by tseekins
(Post 13812909)
It may but again, the primary reason that only the 6.2L trucks can mount a plow is because only the 6.2L trucks have a hydraulic PS unit whereas all other trucks are using the EPAS. (electric power assist steering) This system is apparently demanding too much electrical power to share with a new plow system.
Didn't Ford delete the option for plows on F150's 2013 and up?
Originally Posted by senix
(Post 13817394)
I'm not going to play with it but maybe it's available on a RCLB truck. |
Sno-Way makes a plow setup that is designed to work with the ecoboost. They're the only ones I've found.
Sno-Way Snowplows and snow removal equipment |
We make a plow that mounts to 2011-2013 4x4 F-150s with the EcoBoost engine. You can read about it here and order one here.
If you have any questions about our SnowSport plows, please don't hesitate to ask. |
