Plow on EcoBoost - Ford Truck Enthusiasts Forums
EcoBoost (all engine sizes) 3.5L Twin Turbo EcoBoost V6, 2.7 Twin Turbo EcoBoost V6, 2.3l/2.0L I4 EcoBoost Engines
Plow on EcoBoost
Old 09-03-2013, 01:10 PM
coonman111 coonman111 is offline
coonman111 is starting off with a positive reputation.
Plow on EcoBoost
Can you put a plow on a 150 with the EcoBoost motor.
Old 09-04-2013, 12:25 PM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
Quote:
No, because of the EPAS, Electric Power Assist Steering. Only the 6.2L trucks are plow rated because they have conventional steering. The electric load would be too demanding in the system.
Old 09-04-2013, 12:30 PM
Thank you.
Old 09-04-2013, 12:47 PM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
I don't know coonman. I've seen lots of people put plows on trucks that aren't rated for it, and the steering system is still rated for the full max GAWR which depending on configuration may support a small plow.
I wouldn't put a plow on a half-ton truck, but if you want to I wouldn't let the steering stop you. What does the steering gear care whether you have a plow or not as long as you stay under your front GAWR?
Old 09-04-2013, 12:52 PM
Tom's Avatar
Just did some searching around, and there are people who have put plows on their EB trucks. Do some reading at Plowsite.com.
http://www.plowsite.com/showthread.php?t=136136
One plow outfitter mentions putting them on more than a few EB trucks without issue.
Old 09-04-2013, 01:32 PM
tseekins's Avatar
I hear ya Tom but it's not a weight issue, it's an electrical load issue. There's no factory plow prep package available to beef up the front end on a truck equipped with EPAS. You can't even build one on Ford site.
If Ford sees that a plow was mounted to a truck with no plow prep package, warranty claims could be denied.
But hey, not my truck.
Old 12-05-2013, 09:17 PM
RISUPERCREWMAN RISUPERCREWMAN is offline
RISUPERCREWMAN is gaining momentum as a positive member of FTE.
I would think that the plow would restrict air flow to the inter cooler?
Old 12-05-2013, 10:24 PM
tseekins's Avatar
Quote:
It may but again, the primary reason that only the 6.2L trucks can mount a plow is because only the 6.2L trucks have a hydraulic PS unit whereas all other trucks are using the EPAS. (electric power assist steering) This system is apparently demanding too much electrical power to share with a new plow system.
Old 12-05-2013, 10:29 PM
Tom's Avatar
The PCM measures temps on both sides of the CAC, and it has pretty accurate knock sensors. There are lots of things that can be adjusted to lack of CAC efficiency, so you wouldn't hurt anything.
Quote:
I wonder when we'll have a high capacity alternator available for these things. Of course mine has to get out of the shop for it to even matter.
Old 12-07-2013, 07:49 AM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Didn't Ford delete the option for plows on F150's 2013 and up?
Old 12-07-2013, 06:47 PM
tseekins's Avatar
Quote:
I just went on the build and price site and built a 4x4 XLT with the 6.2L and the plow prep package was not an option like it was in the past.
I'm not going to play with it but maybe it's available on a RCLB truck.
Old 12-08-2013, 12:08 PM
03 SVT VERT 03 SVT VERT is offline
03 SVT VERT has a good reputation on FTE.03 SVT VERT has a good reputation on FTE.03 SVT VERT has a good reputation on FTE.
Sno-Way makes a plow setup that is designed to work with the ecoboost. They're the only ones I've found.
Sno-Way Snowplows and snow removal equipment
Old 12-09-2013, 11:30 AM
ACCESS's Avatar
ACCESS ACCESS is online now
SPONSOR
ACCESS is starting off with a positive reputation.
We make a plow that mounts to 2011-2013 4x4 F-150s with the EcoBoost engine. You can read about it here and order one here.
If you have any questions about our SnowSport plows, please don't hesitate to ask.
Ecoboost and front hitch cnvF250 2009 - 2014 F150 5 03-08-2012 11:30 AM
ecoboost tuner lightninquick 2009 - 2014 F150 10 02-21-2012 10:04 AM
Snow plow prep package for 2011 F-150's tseekins 2009 - 2014 F150 10 08-18-2011 11:21 AM
Ecoboost muffler Rancheroracer EcoBoost (all engine sizes) 0 03-01-2011 03:13 AM
Snow Plow Pump Pastmaster 1999 to 2016 Super Duty 6 09-26-2002 08:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
