Fuel Gauge
Yesterday, I started my truck and the LOW FUEL indicator light came on.
Fuel Gauge showed empty, but I had just fueled the day before. After driving about a mile, and then restarting, it now works again. Any ideas? |
iffy ground?
Or maybe the float stuck down & got freed up after you drove it a little.
ive been parked on steep hills with the front facing down and the fuel gauge has shown empty and the light came on, as soon as i got on level ground i watched it rise, pretty cool since every other time its going down haha
these floats and or sending units in the tank are mounted on the back side of the pick up foot. The tank also dose not have any baffles in it.
If parked nose down you will notice low fuel on ur gauge. If nose up it will show full or fuller than you are. OP..... Most likely if you ran it below a 1/4 tank before filling up like Bill mentioned it probably got stuck for a bit then freed back up. Watch your mileage per tank and if it keeps reoccurring then might need to drop the tank and inspect, also a good time for hutch and harpoon. |
Thanks everyone. Jim
I am experiencing this problem... did a search and found that a lot of people have too. But no resolution was posted.
Originally Posted by bakerbuilttracks
(Post 13200600)
Originally Posted by diehardstroker
(Post 13625936)
Seems like a good solution to me right here and a good explanation
The issue I'm seeing is this... and it's happened twice so far. With a full tank of fuel... driving down the street the gauge would immediately go to emply, fuel light comes on. Pull over, turn engine off, restart and fuel guage would read normally again. Did the same thing this morning. |
maybe an electrical connection issue?? Im not to sure about that, could maybe be a faulty float, I dont know... :-huh
Originally Posted by rtalich
(Post 13626229)
Thanks!! Kind of I guess. I guess I was looking for the smoking gun... I don't want to go thru the trouble of dropping the tank and not finding the problem, you know what I mean?
