Fuel Gauge - Ford Truck Enthusiasts Forums
Fuel Gauge
Old 05-27-2013, 06:16 AM
hammer65 hammer65 is offline
hammer65 is gaining momentum as a positive member of FTE.hammer65 is gaining momentum as a positive member of FTE.
Fuel Gauge
Yesterday, I started my truck and the LOW FUEL indicator light came on.
Fuel Gauge showed empty, but I had just fueled the day before.
After driving about a mile, and then restarting, it now works again.
Any ideas?
Old 05-27-2013, 09:06 AM
lartross's Avatar
lartross lartross is offline
lartross is gaining momentum as a positive member of FTE.
iffy ground?
Old 05-27-2013, 12:32 PM
guitarpicr's Avatar
guitarpicr guitarpicr is offline
guitarpicr has a very good reputation on FTE.guitarpicr has a very good reputation on FTE.guitarpicr has a very good reputation on FTE.
Or maybe the float stuck down & got freed up after you drove it a little.
Old 05-27-2013, 02:02 PM
diehardstroker's Avatar
diehardstroker diehardstroker is offline
diehardstroker has a good reputation on FTE.diehardstroker has a good reputation on FTE.
ive been parked on steep hills with the front facing down and the fuel gauge has shown empty and the light came on, as soon as i got on level ground i watched it rise, pretty cool since every other time its going down haha
Old 05-27-2013, 11:05 PM
bakerbuilttracks's Avatar
bakerbuilttracks bakerbuilttracks is offline
bakerbuilttracks is starting off with a positive reputation.
these floats and or sending units in the tank are mounted on the back side of the pick up foot. The tank also dose not have any baffles in it.
If parked nose down you will notice low fuel on ur gauge. If nose up it will show full or fuller than you are.
OP..... Most likely if you ran it below a 1/4 tank before filling up like Bill mentioned it probably got stuck for a bit then freed back up.
Watch your mileage per tank and if it keeps reoccurring then might need to drop the tank and inspect, also a good time for hutch and harpoon.
Old 05-28-2013, 05:29 AM
Thanks everyone. Jim
Old 10-14-2013, 08:21 AM
rtalich rtalich is offline
rtalich is starting off with a positive reputation.
I am experiencing this problem... did a search and found that a lot of people have too. But no resolution was posted.
Old 10-14-2013, 08:38 AM
Seems like a good solution to me right here and a good explanation
Old 10-14-2013, 09:59 AM
Quote:
Thanks!! Kind of I guess. I guess I was looking for the smoking gun... I don't want to go thru the trouble of dropping the tank and not finding the problem, you know what I mean?
The issue I'm seeing is this... and it's happened twice so far. With a full tank of fuel... driving down the street the gauge would immediately go to emply, fuel light comes on. Pull over, turn engine off, restart and fuel guage would read normally again. Did the same thing this morning.
Old 10-14-2013, 03:48 PM
maybe an electrical connection issue?? Im not to sure about that, could maybe be a faulty float, I dont know...
Old 10-16-2013, 10:50 AM
microdevil45's Avatar
microdevil45 microdevil45 is offline
microdevil45 is gaining momentum as a positive member of FTE.
If you go through the trouble of dropping the tank go ahead and do the hutch and harpoon mod while your in there. Also would be a good time to replace that pickup foot since it is more than likely broken. Also give you a reason to inspect your tank and replace the sending unit for the fuel if needed. So in other words it would be worth it. IMHO
Fuel gauge Diesel_Brad 1987 - 1996 F150 & Larger F-Series Trucks 22 08-09-2015 07:09 PM
Fuel Gauge Accuracy tractoman 1994.5 - 1997 7.3L Power Stroke Diesel 5 05-08-2014 01:22 PM
fuel gauge incorrect phase_one 1997-2006 Expedition & Navigator 4 03-17-2014 12:29 PM
fuel pressure gauge ihandy 6.0L Power Stroke Diesel 5 09-14-2013 06:37 PM
2007 F-150 fuel gauge issue king_triton 2004 - 2008 F150 1 07-21-2013 04:53 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
