05 5.4 no start
I have 05 F150 xlt 5.4. problem started with fuel /alt guage. drove truck into my garage to check for a pal of mine. Went to start to check things over and no start. checked fuses, inertia swith, replaced fpdm, checked wires on frame under drivers side, got a new pump, took out old pump and it seems ok. Any ideas. No codes.
Fuel pressure ? Spark ? Injector pulse ? ECM communication , live data ? Correct ignition key ? More info please .
ive heard of the fuel pump driver module being a problem there is a thread about that. it corrodes pretty badly.
Originally Posted by 7636074460
(Post 13098694)
yes i have spark,also injector pulse,reprogrammed key,battery good, turns over good, scan tool said,all ok.
Originally Posted by jacksonl
(Post 13100245)
If it will run with starting fluid ^^^ , that shows a fuel issue . Not enough pressure , bad fuel , ect . I just towed a 95 F150 yesterday . It had a 1/2 tank of H2o ! Guy says he drove it home and had a no start the next morning after buying fuel ! I find that hard to believe , but , he is a regular customer .??? Maybe the punks next door put water in his tank ?
Hey guys, sorry but been out of town. Yes it starts with starting fluid. I dropped the tank, replaced pump and still no fuel. Also replaced fpdm , no difference. Had truck for two weeks at home. Stumped, help.
Have you checked fuel pressure , fuel quality ? Do you have power and ground at the pump ?
Is the security system kick in the red light on the dash will blink rapidly when you try to turn it over i just went thru the same problems a week ago it ended up being the fuse block assembly the ford tech called it a smart module i called it 700 bucks
