05 5.4 no start - Ford Truck Enthusiasts Forums
05 5.4 no start
Old 04-24-2013, 07:40 PM
jacksonl jacksonl is offline
jacksonl is starting off with a positive reputation.
05 5.4 no start
I have 05 F150 xlt 5.4. problem started with fuel /alt guage. drove truck into my garage to check for a pal of mine. Went to start to check things over and no start. checked fuses, inertia swith, replaced fpdm, checked wires on frame under drivers side, got a new pump, took out old pump and it seems ok. Any ideas. No codes.
Old 04-24-2013, 08:09 PM
JWC 3's Avatar
JWC 3 JWC 3 is offline
JWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputation
Fuel pressure ? Spark ? Injector pulse ? ECM communication , live data ? Correct ignition key ? More info please .
Old 04-24-2013, 10:32 PM
7636074460 7636074460 is offline
7636074460 is gaining momentum as a positive member of FTE.
ive heard of the fuel pump driver module being a problem there is a thread about that. it corrodes pretty badly.
Old 04-24-2013, 10:56 PM
Nalb1221's Avatar
Nalb1221 Nalb1221 is offline
Nalb1221 is starting off with a positive reputation.
Quote:
He said he replaced that. Is the engine turning, you know trying to start?
Old 04-25-2013, 12:11 PM
yes i have spark,also injector pulse,reprogrammed key,battery good, turns over good, scan tool said,all ok.
Old 04-25-2013, 06:00 PM
ojai150 ojai150 is offline
ojai150 is starting off with a positive reputation.
Quote:
Have you tried spraying some starter fluid into air cleaner while cranking?
Old 04-25-2013, 10:45 PM
JWC 3's Avatar
If it will run with starting fluid ^^^ , that shows a fuel issue . Not enough pressure , bad fuel , ect . I just towed a 95 F150 yesterday . It had a 1/2 tank of H2o ! Guy says he drove it home and had a no start the next morning after buying fuel ! I find that hard to believe , but , he is a regular customer .??? Maybe the punks next door put water in his tank ?
Old 05-10-2013, 02:36 PM
Hey guys, sorry but been out of town. Yes it starts with starting fluid. I dropped the tank, replaced pump and still no fuel. Also replaced fpdm , no difference. Had truck for two weeks at home. Stumped, help.
Old 05-10-2013, 05:26 PM
dos0711's Avatar
dos0711 dos0711 is offline
dos0711 is starting off with a positive reputation.
Last edited by dos0711; 05-10-2013 at 05:27 PM. Reason: Question was already answered
Old 05-10-2013, 08:04 PM
JWC 3's Avatar
Have you checked fuel pressure , fuel quality ? Do you have power and ground at the pump ?
Old 05-11-2013, 07:00 AM
Ducky F150 Ducky F150 is offline
Ducky F150 is starting off with a positive reputation.
Is the security system kick in the red light on the dash will blink rapidly when you try to turn it over i just went thru the same problems a week ago it ended up being the fuse block assembly the ford tech called it a smart module i called it 700 bucks
Help- 2001 5.4 cranks but won't start Dstosh 1999 to 2016 Super Duty 4 03-26-2016 06:07 PM
HPTuner Jonnywayne Modular V8 (4.6L, 5.4L) 0 02-13-2016 12:57 PM
fuel pump wiring agns 1999 to 2016 Super Duty 4 07-14-2015 06:32 AM
05 gas gauge 5.4L short bed steelbill58 Modular V8 (4.6L, 5.4L) 1 05-14-2014 09:31 AM
Fuel gauge fix 05 super duty 5.4L steelbill58 1999 to 2016 Super Duty 0 04-27-2014 06:23 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
