2010 Limited with Tire Pressure Sensor Fault
My new to me 2010 will light up a TPS Fault about every other day usually on the trip home. It will beep a few times, flash for a while and either go out after about 10 minutes or go out when I drive it next. I keep checking my tires and they are fine. I read through the forum and it seems the belt type sensors are a pain and often unreliable. Vehicle has 57k .. is CPO so underwarranty has great tires etc. I am thinking about just buying 4 new OEM Ford sensors ( not belt type) and putting them on and not dorking around with the dealer . I can get a set for around 60 bucks. Any suggestions would be appreciated.
Before you do that, check the spare tire sensor. I've seen friends who's TPS light comes on and they try everything but checking the spare. It has a sensor also.
Just my 2 cents. |
Originally Posted by expoman55
(Post 12961237)
Originally Posted by GITanker
(Post 13149907)
Just my 2 cents. Matt |
