2006 6.0 Glow plug system
Hi to all, I have a 2006 F350 dulley with a 6.0. A while back i got a code for #8 glow plug and had the warrenty fix it. Well the warrenty is over now and I want to fix my newest problem.
I have a code P0671 cylinder 1 glow plug circuit and the engine light is on. So I would like to replace all the glow plugs and harneses. Could someone help me with the part numbers for what I need to fix this. I figure I will replace all and not have any problems for a while. I have just under 88K on the 6.0. Thank you in advance for any help offered. Willi |
2006 FORD F-350 SUPER DUTY Parts - Tousley Ford Parts Depot
2006 FORD F-350 SUPER DUTY Parts - Tousley Ford Parts Depot You may need a special tool to remove the harness from the glow plug.. Not too sure tho. |
the tool is junk. its used to prevent damage to the harness dont count on that to work
Originally Posted by jedlicka87
(Post 12867485)
2006 FORD F-350 SUPER DUTY Parts - Tousley Ford Parts Depot You may need a special tool to remove the harness from the glow plug.. Not too sure tho. Thanks for the reply. I will check them out Willi |
Okay, I'll bite. I just tried those links and they didn't look right, so here are the part numbers for your 2006:
4C2Z-12A690-AB (Glow plug harness right side) 5C3Z-12A690-A (Glow plug harness left side) ZD-13 (Glow plug) Ditto on Moe's comment regarding the glow plug harness removal tool. It is almost as useless as TiT$ on a bull. |
why are the the two prices so far off?
Originally Posted by m-chan68
(Post 12868410)
4C2Z-12A690-AB (Glow plug harness right side) 5C3Z-12A690-A (Glow plug harness left side) ZD-13 (Glow plug) Ditto on Moe's comment regarding the glow plug harness removal tool. It is almost as useless as TiT$ on a bull. I checked out the link and they did look like motorcraft glow plugs. I did find the same ZD-13 so thats cool. I will have to look for the left and right side. Thanks for the reply Willi |
