2006 6.0 Glow plug system - Ford Truck Enthusiasts Forums
Old 02-21-2013, 02:48 PM
Hwilli Hwilli is offline
Hwilli is starting off with a positive reputation.
Hi to all, I have a 2006 F350 dulley with a 6.0. A while back i got a code for #8 glow plug and had the warrenty fix it. Well the warrenty is over now and I want to fix my newest problem.
I have a code P0671 cylinder 1 glow plug circuit and the engine light is on. So I would like to replace all the glow plugs and harneses. Could someone help me with the part numbers for what I need to fix this. I figure I will replace all and not have any problems for a while. I have just under 88K on the 6.0. Thank you in advance for any help offered.
Willi
Old 02-21-2013, 07:49 PM
jedlicka87's Avatar
jedlicka87 jedlicka87 is offline
jedlicka87 is starting off with a positive reputation.
2006 FORD F-350 SUPER DUTY Parts - Tousley Ford Parts Depot
You may need a special tool to remove the harness from the glow plug.. Not too sure tho.
Old 02-21-2013, 10:29 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
the tool is junk. its used to prevent damage to the harness dont count on that to work
Old 02-21-2013, 11:21 PM
Thanks for the reply. I will check them out
Willi
Old 02-21-2013, 11:36 PM
m-chan68's Avatar
m-chan68 m-chan68 is offline
m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.
Okay, I'll bite. I just tried those links and they didn't look right, so here are the part numbers for your 2006:
4C2Z-12A690-AB (Glow plug harness right side)
5C3Z-12A690-A (Glow plug harness left side)
ZD-13 (Glow plug)
Ditto on Moe's comment regarding the glow plug harness removal tool. It is almost as useless as TiT$ on a bull.
Old 02-22-2013, 09:43 AM
Iaff113's Avatar
Iaff113 Iaff113 is offline
Iaff113 is starting off with a positive reputation.
why are the the two prices so far off?
Old 02-22-2013, 05:14 PM
ZD-13 (Glow plug)
I checked out the link and they did look like motorcraft glow plugs. I did find the same ZD-13 so thats cool. I will have to look for the left and right side. Thanks for the reply
Willi
NEED HELP ASAP! Adam Jacobson 6.0L Power Stroke Diesel 11 11-10-2016 11:01 PM
Losing Power neilwpitts 1999 to 2016 Super Duty 3 12-30-2015 06:35 PM
2006 6.0 222k on it 6ohguy 6.0L Power Stroke Diesel 3 05-06-2015 02:41 AM
Injectors/glow plugs txweslawyer 6.0L Power Stroke Diesel 3 04-12-2014 08:11 AM
Glow plug and valve cover torque specs 2006powerstroke90 1994.5 - 1997 7.3L Power Stroke Diesel 11 12-19-2012 12:00 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
