Vin # problems 1963 Uni S/B
Hi all.
I bought a 1963 Uni short bed project truck about 5 years ago off a guy who never registered it when he bought it. He had the signed transfers, but lost the registration paper. So I contacted the 2nd previous owner and he agreed to get a new copy of the registration. So I'm putting together a package of forms with the VIN ect. all filled out so all he has to do is sign off. The problem I have is the Vin looks wrong (see photo) You guys say it should start with a F10XXXXXX mine is 96642A-4661014L To further confuse me, my son just bought a 1961 Uni s/b, he has the registration, but no VIN tags are on the cab. His registration paper shows VIN # is 4661014L117125A all one # no dash in the middle and his first 7 digits are the same as my last ! I need to know what the correct VIN # is to enter on the paperwork. Thanks Jim http://www.webnameswb.ca/users/2055/...s/63UNIVIN.jpg |
Need to get in touch with the NumberDummy. The number reversed from 61 to 63.
I can halfway decode, but I dont have the books to finish it. |
Your trucks where built up in Canada and have a different numbering system than the US trucks.
The 63 what is the original paint color? 1HH says it would be a solid color truck but I cant find HH in the charts. If your truck had been shipped from the US it would have started with F10 and the DSO would have been B7. |
Thanks for the help, and pointing out the reverse vin's between 61-63 now it's starting to all make sense. So do all Canadian trucks have no VIN tag in thje glove box? Is the frame VIN the complete # or oly part of it? Thanks again. Jim
I have decoded it this far 4 - Ford V8 661 - ?? 0 - F100 14 - 114" wb L - left hand drive (both mine and my sons are the same) 96642 - ?? A - 5000 gvw here is a photo of when we brought the 63 home http://www.webnameswb.ca/users/2055/...mages/My63.jpg |
661 should be just 66. 66 is integral cab (unibody). Then 10 would make it a f100.
Originally Posted by Hillbilly63
(Post 12727741)
vins
nice little S/B...always a diamond in the rough hiding somewhere !
before i found FTE and heard of number dummy i had always called ford archives. in 1980 i bought a 62 ford uni longbed and drove it home, once i realised what i had i wanted to know more. at the time they could verify production and even that it was a mid week build(not sure if he was yanking my chain ) there is alot of helpful people here and good info. as a side note..do all these unibody projects start on the same trailer;) ps. my unis are canadian built |
Would like the information off the warranty plate for the registry.
96642A-4661014L
96642= serial number A= gvw rating 4= Ford V8 66=Integral cab 10=F100 14= 114" wheelbase L= Lefthand Drive |
10 series code refers to either Ford or Mercury 100. The Canadian Rating Plate (as you can see in post 1) has the SERIES listed by itself, specifies which is which.
A = 3,600-5,000 lbs. Gross Vehicle Weight Rating. 1966 (1967/68) Mercury & Ford trucks assembled in Canada use the same Warranty Plate/codes and 11 digit VIN as US trucks. I can decode all the 1965 Ford/Mercury Canadian Rating Plate codes using the 1964/72 truck catalog., but not prior years. 1946/64: Specific year(s) Ford Motor Co. of Canada Ltd parts catalog is required. Only catalog like this I have is 1953. mercurypickups.com has some of this info. |
So it could have read M100 , and would have a 1 or 5 to denote mercury v8 or mercury I-6?
Originally Posted by kjvforme
(Post 12994502)
But these are Ford engines, not Merc's. Specific to Mercury only engine used in the '60's: FE 410 installed in 1966/67 Mercury Parklanes. Why the hell did FoMoCo bother? 390, 427, 428 were also available. |
But wouldnt 1 & 5 engines come with the mercury valve covers.
(Post 12995539)
I know the Mercury FE cars came with Merc valve covers, but once removed...what do you have? A Ford engine! |
