Center Console Help
Does any one know if a 2010 or11 Raptor center console will fit in a 2011 Ford F250? Do you know if the dimensions are the same and if the contour to the dashboard is the same? Thanks so much. I appreciate any help you can give me as I am looking to put a center console in my truck and take out the middle jump seat.I was thinking of putting in a cb were the shifter would be
i doubt the contour is the same where the console meets the lower dash. Even if you did it, the shifter would be useless as the superduty already has a column shift. Find a center console out of a 2011-2012 superduty and that should bolt up.
Where the shifter is on the console i was going to put in a cb radio. I am not sure about the contour on the console i saw pictures but its hard to tell by the pictures i saw
