Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2010+ Ford SVT F150 Raptor
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2010+ Ford SVT F150 Raptor SPONSORED BY:
  #1 (permalink)
Old 01-04-2013, 10:25 PM
250lariat 250lariat is offline
Garage is empty, add now
250lariat is starting off with a positive reputation.
Center Console Help
Does any one know if a 2010 or11 Raptor center console will fit in a 2011 Ford F250? Do you know if the dimensions are the same and if the contour to the dashboard is the same? Thanks so much. I appreciate any help you can give me as I am looking to put a center console in my truck and take out the middle jump seat.I was thinking of putting in a cb were the shifter would be
Click the image to open in full size.
  #2 (permalink)
Old 01-07-2013, 10:45 AM
04XLTRUNNER's Avatar
04XLTRUNNER 04XLTRUNNER is online now
2012 Ford F150
04XLTRUNNER is gaining momentum as a positive member of FTE.04XLTRUNNER is gaining momentum as a positive member of FTE.
i doubt the contour is the same where the console meets the lower dash. Even if you did it, the shifter would be useless as the superduty already has a column shift. Find a center console out of a 2011-2012 superduty and that should bolt up.
__________________
2012 Lariat SC 4x4 5.0. Tuxedo Black, 3.55 E-lock,6.5" MacGaughy Lift, 1.5" AAL, 20" XD Cranks w/ 35" Fuel M/T Rubber, 5Star Tuned, Blacked out upper/lower Grille,Cherry Bomb,Spyder CCFL Halo Projectors, HID's, Full Int. LED, LED 3rd Brake & Taillights, Fire&Ice Bar, LED puddle lamps
Gone:2009 F-150 FX4, 2005 F-150 lariat 4x4 & 2004 F-150 xlt 2x4
  #3 (permalink)
Old 01-07-2013, 06:52 PM
Where the shifter is on the console i was going to put in a cb radio. I am not sure about the contour on the console i saw pictures but its hard to tell by the pictures i saw
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
