Ecoboost is cold blooded like a diesel
Now with cold weather set in I have noticed my Ecoboost is a very cold blooded engine that takes a long time to throw any heat in the cab. Literally no better to warm up than my 7.3L diesel was. My Jeep would defrost the window in 5 minutes or less. This Ecoboost truck doesn't even melt a few frost crystals in 5 minutes, let alone touch ice.
Also, I notice it guzzles gas like a drunk at a beer party until the engine gets pretty warm. Then suddenly it seems the system goes closed loop and the fuel meter suddenly takes a jump up. Boy, this is going to be a looooong winter waiting for windows to defrost in parking lots. Pretty disappointed with that. |
well i have seen the same out of my 5.0 but i live where 55 is cold and i park in a stall so my windows never fog up at home.
you could put a block warmer in but it will only work where theres power. |
Mine dont seem that slow to heat...
BUT, I do appreciate the heated side of the heated and cooled seats more now.;) |
Yes....it will be a little rough on the MPG, until the engine reaches full normal operating temp.
Funny you should say that it takes awhile to warm up, as I was just thinking a couple of days ago, about how fast my Ecoboost warms up. I can do a cold start up on a 10 degree morning, put it in gear and go....and have full heat blasting from the floor or vents within 2 miles. |
Originally Posted by blueovelboy
(Post 12532497)
Originally Posted by QwkTrip
(Post 12532359)
Also, I notice it guzzles gas like a drunk at a beer party until the engine gets pretty warm. Then suddenly it seems the system goes closed loop and the fuel meter suddenly takes a jump up. Boy, this is going to be a looooong winter waiting for windows to defrost in parking lots. Pretty disappointed with that. Anyway here are some links: Kat's Handi-Heat Magnetic Heater 300 Watt, Model# 1160 | Engine Heaters Blankets| Northern Tool + Equipment :-wink |
I agree with SabreFX4 mine doesn't take long to warm up.. 2 km down the road I start getting heat. I only let it iddle a couple minutes prior to driving. Mine doesn't seem to take any longer to warm up than my 1998 Chevy with a 350.
I am also pleased about how quickly my eco warms up! Temperatures are usually -20 or lower in the morning and 10 minutes later she's nice and toasty inside, seats and all. The heated seats are great as they turn on when i use my command start, great feature.
:-jamminHeated seats
Mine is fast as well. I do have the system set to use the last control setting w/ the remote start. I always set to defrost the night before. That way it starts blowing air immediately.
Auto setting seems to take a while since it will not start blowing air until it reaches a certain temp which seems to be hot instead of just warm. |
I test drove one last year. It was 30 degrees out and i got there at 8 in the morning. The truck hadnt been started yet that day. I started it and pulled out on the highway and i was getting heat 2 miles down the road.
It was the fastest heating vehicle i have been in to date. I figured it was due to the water cooled turbos. The exhaust heat is going directly into the cooling system. |
it was about 44 degrees this morning when I started my truck. 5 minutes at idle and it was blowing hot air.
OP you might put in a remote start and set the heat before you get out at night. just a thought!
have you tried to see if the blend door is opening up or not? |
Mine heats up fast and defrosts well but not quite as well as my '04 expy.
We can get real nostalgic here and take about the late 80's trucks. :p Took forever to get heated up. |
after about 10 mins startup the needle moves on the heat a tad. once i get down my long road to the highway (30km/hr 15mph) then get going 50km/30mph the gauge goes to half in no time!
