Ecoboost is cold blooded like a diesel - Ford Truck Enthusiasts Forums
Old 11-28-2012, 01:05 AM
QwkTrip's Avatar
QwkTrip QwkTrip is offline
QwkTrip is a splendid one to beholdQwkTrip is a splendid one to beholdQwkTrip is a splendid one to beholdQwkTrip is a splendid one to beholdQwkTrip is a splendid one to beholdQwkTrip is a splendid one to behold
Now with cold weather set in I have noticed my Ecoboost is a very cold blooded engine that takes a long time to throw any heat in the cab. Literally no better to warm up than my 7.3L diesel was. My Jeep would defrost the window in 5 minutes or less. This Ecoboost truck doesn't even melt a few frost crystals in 5 minutes, let alone touch ice.
Also, I notice it guzzles gas like a drunk at a beer party until the engine gets pretty warm. Then suddenly it seems the system goes closed loop and the fuel meter suddenly takes a jump up.
Boy, this is going to be a looooong winter waiting for windows to defrost in parking lots. Pretty disappointed with that.
Old 11-28-2012, 03:11 AM
blueovelboy's Avatar
blueovelboy blueovelboy is offline
blueovelboy has a very good reputation on FTE.blueovelboy has a very good reputation on FTE.blueovelboy has a very good reputation on FTE.blueovelboy has a very good reputation on FTE.
well i have seen the same out of my 5.0 but i live where 55 is cold and i park in a stall so my windows never fog up at home.
you could put a block warmer in but it will only work where theres power.
Old 11-28-2012, 08:10 AM
BigDfromTN's Avatar
BigDfromTN BigDfromTN is offline
BigDfromTN is gaining momentum as a positive member of FTE.BigDfromTN is gaining momentum as a positive member of FTE.
Mine dont seem that slow to heat...
BUT, I do appreciate the heated side of the heated and cooled seats more now.
Old 11-28-2012, 09:51 AM
SabreFX4 SabreFX4 is offline
SabreFX4 is gaining momentum as a positive member of FTE.SabreFX4 is gaining momentum as a positive member of FTE.
Yes....it will be a little rough on the MPG, until the engine reaches full normal operating temp.
Funny you should say that it takes awhile to warm up, as I was just thinking a couple of days ago, about how fast my Ecoboost warms up. I can do a cold start up on a 10 degree morning, put it in gear and go....and have full heat blasting from the floor or vents within 2 miles.
Old 11-28-2012, 10:49 AM
PrinceValium's Avatar
PrinceValium PrinceValium is offline
PrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to all
I have seen many mornings in the 30's...I ride my motorcycle often until it gets close to freezing. Although we have pretty good temps most of the time, 55 degrees would be great if it stayed that way in the winter.
Old 11-28-2012, 10:57 AM
I was looking around and saw where people are using these magnetic block heaters for their trucks. Where I do understand the need for them and their benefit (we have them on our cogeneration engines at work) I wonder if having them always heating the oil breaks it down prematurely?
Anyway here are some links:
Kat's Handi-Heat Magnetic Heater — 300 Watt, Model# 1160 | Engine Heaters Blankets| Northern Tool + Equipment
Amazon.com: Kat's 1153 Handi-Heat 200 Watt Magnetic Heater: Automotive Amazon.com: Kat's 1153 Handi-Heat 200 Watt Magnetic Heater: Automotive
Old 11-28-2012, 11:27 AM
Christin Christin is offline
Christin is starting off with a positive reputation.
I agree with SabreFX4 mine doesn't take long to warm up.. 2 km down the road I start getting heat. I only let it iddle a couple minutes prior to driving. Mine doesn't seem to take any longer to warm up than my 1998 Chevy with a 350.
Old 11-28-2012, 11:44 AM
00xlt 00xlt is offline
00xlt is starting off with a positive reputation.
I am also pleased about how quickly my eco warms up! Temperatures are usually -20 or lower in the morning and 10 minutes later she's nice and toasty inside, seats and all. The heated seats are great as they turn on when i use my command start, great feature.
Old 11-28-2012, 11:58 AM
Papa Tiger's Avatar
Papa Tiger Papa Tiger is online now
Papa Tiger has a very good reputation on FTE.Papa Tiger has a very good reputation on FTE.Papa Tiger has a very good reputation on FTE.
Heated seats
Old 11-28-2012, 12:07 PM
thomastl thomastl is offline
thomastl is starting off with a positive reputation.
Mine is fast as well. I do have the system set to use the last control setting w/ the remote start. I always set to defrost the night before. That way it starts blowing air immediately.
Auto setting seems to take a while since it will not start blowing air until it reaches a certain temp which seems to be hot instead of just warm.
Old 11-28-2012, 02:15 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD BURNSTOUGHFORD is offline
BURNSTOUGHFORD has a good reputation on FTE.BURNSTOUGHFORD has a good reputation on FTE.
I test drove one last year. It was 30 degrees out and i got there at 8 in the morning. The truck hadnt been started yet that day. I started it and pulled out on the highway and i was getting heat 2 miles down the road.
It was the fastest heating vehicle i have been in to date. I figured it was due to the water cooled turbos. The exhaust heat is going directly into the cooling system.
Old 11-28-2012, 02:56 PM
04XLTRUNNER's Avatar
04XLTRUNNER 04XLTRUNNER is offline
04XLTRUNNER is gaining momentum as a positive member of FTE.04XLTRUNNER is gaining momentum as a positive member of FTE.
it was about 44 degrees this morning when I started my truck. 5 minutes at idle and it was blowing hot air.
Old 11-28-2012, 05:54 PM
OP you might put in a remote start and set the heat before you get out at night. just a thought!
have you tried to see if the blend door is opening up or not?
Old 11-28-2012, 06:08 PM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
Mine heats up fast and defrosts well but not quite as well as my '04 expy.
We can get real nostalgic here and take about the late 80's trucks. Took forever to get heated up.
Old 11-28-2012, 08:09 PM
TheStuffz's Avatar
TheStuffz TheStuffz is offline
TheStuffz is gaining momentum as a positive member of FTE.TheStuffz is gaining momentum as a positive member of FTE.
after about 10 mins startup the needle moves on the heat a tad. once i get down my long road to the highway (30km/hr 15mph) then get going 50km/30mph the gauge goes to half in no time!
ATTENTION ECOBOOST OWNERS 12secrd EcoBoost (all engine sizes) 32 03-20-2013 08:17 PM
Cold Blooded Warm Up Issues bigslurrp 1994.5 - 1997 7.3L Power Stroke Diesel 7 03-13-2013 10:32 PM
Trouble in Baja? (Ecoboost 2011 F-150) 640 CI Aluminum FORD 2009 - 2014 F150 29 10-26-2010 04:32 PM
AC coming through the defrost vents? BigRy Excursion - King of SUVs 7 10-10-2009 08:46 AM
cold blooded EFI ssap108 Fuel Injection, Carburetion & Fuel System 3 10-12-2003 12:40 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
