2012 Expedition courtesy lights disable
I just bought a new 2012 expedition to replace my 2006 expedition. I love the new one. I am amazed how different from my 2006 it is.
I am in NY, i bought it from a dealer in Texas, Holiday Ford. I got an amazing deal. They took 30% off sticker, and charged me $1000 to deliver to NYC. Does anyone know how to turn off the courtesy lights that come on when i open the doors, turn off the car, or unlock the doors? I do not like the parking lights and instrument lights coming on, those bulbs will wear out quickly. That is my only gripe on this, its a great truck. |
You can make it so the interior lights do not come on when opening the doors by rotating the dimmer switch all the way down past the detent.
I saw something before about the approach lamps disable procedure, will check on it when I get home. Matt |
HaHa, I knew I saw it before ( I posted it for another member on the other site awhile back :-X04 )
Anyways, according to my owners manual ( 2008MY ) the procedure is as follows. Just keep in mind it may or may not work on the 2012's. Deactivating/activating perimeter lamps illuminated entry You may perform the following power door lock sequence to enable/disable the perimeter lamps feature. Note: Before starting, ensure the ignition is in the 1 (LOCK) position and all vehicle doors are closed. You must complete Steps 1–5 within 30 seconds or the procedure will have to be repeated. If the procedure needs to be repeated, wait a minimum of 30 seconds before beginning again. 1. The ignition must be OFF to begin the sequence. 2. Place the key in the ignition and turn the ignition to the 3 (RUN) position. 3. Press the power door unlock control on the door panel three times. 4. Turn the ignition from the 3 (RUN) position to the 1 (LOCK) position. 5. Press the power door unlock control on the door panel three times. 6. Turn the ignition back to the 3 (RUN) position. The horn will chirp one time to confirm programming mode has been entered and is active. 7. Press the power door unlock control twice within 5 seconds. Note: The horn will chirp once to indicate the perimeter lighting feature has been deactivated. The horn will chirp once and honk once (one short and one long) to indicate the perimeter lighting feature has been activated. 8. Turn the ignition to the 1 (LOCK) position to exit the procedure. Note: The horn will chirp once to confirm the procedure is complete. Let me know how you make out. Matt |
Thank you. I will give it a shot tomorrow.
