Oil system upgrades/maintenance - let's get the info together!
While I've got my cooling system thread going on I decided it would be a good idea to get the oiling system upgrades/maintenance taken care of as well. There's not really gonna be a lot to it, but here's what I've got:
Drain and refill oiling system with Rotella T6 5W-40 and Rev-X Motorcraft oil filter Motorcraft oil filter cap Install Fumoto drain valve for oil drain Motorcraft oil cooler Motorcraft updated STC fitting Motorcraft updated HPOP screen Motorcraft updated dummy plugs Motorcraft updated stand pipes Motorcraft updated turbo oil feed line Motorcraft updated turbo oil return line Motorcraft updated oil dipstick Optional: Install aftermarket metal oil filter cap (BPD or Sinister) Install aftermarket metal oil fill cap (BPD) Install aftermarket bypass oil filter setup (BPD) Install aftermarket oil cooler assembly (IPPR or BPD) I do know that IPR makes the external oil cooler setup for the OEM cooler and BPD makes their liquid/air oil cooler setup as well, but as stated in my cooling system thread I like the ability to heat the oil with the coolant so BPD's kit is out, not to mention it's very pricey. IPR's setup seems to only be a good idea for those people who don't DIY, and I don't like the idea of all the extra hoses and making it harder to do an oil change. Is there anything I might be missing? Wasn't there something about changing stand pipes and dummy plugs? Just looking for anything to do with the oiling system. Thanks! |
Sorry to hijack with a dumb question. What does STC stand (on the HPOP)for?
I do plan on the BPD upgrade and want to tackle all the other little issues while it is apart. Sounds like what you are doing. |
Snap to connect fitting.
Here's a pic of an '06 oil pump with the update branch tube fitting. It's the T shape piece near the drive gear in the back. An STC fitting looks exactly the same (and goes in the same place) except on the short piece of tubing there is a sliding piece that allows the installer to line every thing up easier/correctly when reinstalling the pump assembly. An updated STC fitting really isn't "snap to connect", it comes with a plastic bracket and holding hardware to ensure the T part of the fitting is lined up correctly to the pump before the whole assembly is installed. The plastic bracket and holding hardware is removed before installation.
https://www.ford-trucks.com/forums/p...ctureid=102325 |
Originally Posted by the_auto_tech
(Post 12399755)
Perform oiling system flush with Seafoam and Hot Shot Drain and refill oiling system with Rotella T6 5W-40 Replace oil filter with Motorcraft filter Install Fumoto drain valve for oil drain Replaced oil cooler with new OEM unit Install updated STC fitting on HPOP Install updated screen for HPOP I do know that IPR makes the external oil cooler setup for the OEM cooler and BPD makes their liquid/air oil cooler setup as well, but as stated in my cooling system thread I like the ability to heat the oil with the coolant so BPD's kit is out, not to mention it's very pricey. IPR's setup seems to only be a good idea for those people who don't DIY, and I don't like the idea of all the extra hoses and making it harder to do an oil change. Is there anything I might be missing? Wasn't there something about changing stand pipes and dummy plugs? Just looking for anything to do with the oiling system. Thanks! |
Originally Posted by 69cj
(Post 12401094)
In case you don't know, the 6.0 retains 3 to 4 qts. of existing oil when doing an oil change, therefore you will not be getting all of your additives out when you do the oil change/ flush.
The only time I performed a Oil system flush using kinda similar additives, it did not end well. I have successfully removed water from a boat oil sump doing multiple changes of cheap oil tho. No additives tho diesel was recommended. |
I don't think I would be interested in doing an oil system flush with anything but fresh oil :-X15.
(Post 12401094)
Originally Posted by 2112
(Post 12401275)
I did not know it was that much.
Originally Posted by Rusty Axlerod
(Post 12401400)
So, are there any other oiling system "updated" parts I might be missing? I thought I read somewhere the dummy plugs and stand pipes were updated? Anything else?
(Post 12402758)
Don't forget updated stand pipes and dummy plugs.
(Post 12402850)
Fumoto drain valve on the oil pan. Saves a possible mess and your in total control.
Originally Posted by Crash16
(Post 12402891)
Let's keep it going! I am wanting to get the complete list so I can start ordering parts for the rebuild! |
I just replaced my turbo feed tube and oil pressure gauge (OPG).
I had to take the tube off to get to the OPG so I upgraded it. If you have the braided feed tube, it's recommended you upgrade. The OPG would frequently indicate no oil pressure and make my "check gage" lite come on. My OPG sensor wire was soaked with oil and it's a common problem with this gauge. It was a PITA to get to this sensor once it's back on the engine. it's only $30 at your local ford dealer. |
I think that may have already been done on this truck but I will check into it for sure!
Bumping this up!
