Oil system upgrades/maintenance - let's get the info together! - Ford Truck Enthusiasts Forums
Old 10-22-2012, 11:38 AM
the_auto_tech's Avatar
the_auto_tech the_auto_tech is offline
the_auto_tech has a good reputation on FTE.the_auto_tech has a good reputation on FTE.the_auto_tech has a good reputation on FTE.
While I've got my cooling system thread going on I decided it would be a good idea to get the oiling system upgrades/maintenance taken care of as well. There's not really gonna be a lot to it, but here's what I've got:
Drain and refill oiling system with Rotella T6 5W-40 and Rev-X
Motorcraft oil filter
Motorcraft oil filter cap
Install Fumoto drain valve for oil drain
Motorcraft oil cooler
Motorcraft updated STC fitting
Motorcraft updated HPOP screen
Motorcraft updated dummy plugs
Motorcraft updated stand pipes
Motorcraft updated turbo oil feed line
Motorcraft updated turbo oil return line
Motorcraft updated oil dipstick
Optional:
Install aftermarket metal oil filter cap (BPD or Sinister)
Install aftermarket metal oil fill cap (BPD)
Install aftermarket bypass oil filter setup (BPD)
Install aftermarket oil cooler assembly (IPPR or BPD)
I do know that IPR makes the external oil cooler setup for the OEM cooler and BPD makes their liquid/air oil cooler setup as well, but as stated in my cooling system thread I like the ability to heat the oil with the coolant so BPD's kit is out, not to mention it's very pricey. IPR's setup seems to only be a good idea for those people who don't DIY, and I don't like the idea of all the extra hoses and making it harder to do an oil change.
Is there anything I might be missing? Wasn't there something about changing stand pipes and dummy plugs? Just looking for anything to do with the oiling system. Thanks!
Old 10-22-2012, 12:44 PM
2112's Avatar
2112 2112 is offline
2112 is starting off with a positive reputation.
Sorry to hijack with a dumb question. What does STC stand (on the HPOP)for?
I do plan on the BPD upgrade and want to tackle all the other little issues while it is apart. Sounds like what you are doing.
Old 10-22-2012, 12:50 PM
Snap to connect fitting.
Old 10-22-2012, 05:31 PM
Rusty Axlerod's Avatar
Rusty Axlerod Rusty Axlerod is offline
Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.
Here's a pic of an '06 oil pump with the update branch tube fitting. It's the T shape piece near the drive gear in the back. An STC fitting looks exactly the same (and goes in the same place) except on the short piece of tubing there is a sliding piece that allows the installer to line every thing up easier/correctly when reinstalling the pump assembly. An updated STC fitting really isn't "snap to connect", it comes with a plastic bracket and holding hardware to ensure the T part of the fitting is lined up correctly to the pump before the whole assembly is installed. The plastic bracket and holding hardware is removed before installation.
Old 10-22-2012, 06:47 PM
69cj's Avatar
69cj 69cj is online now
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
Quote:
Perform oiling system flush with Seafoam and Hot Shot
Replace oil filter with Motorcraft filter
Replaced oil cooler with new OEM unit
Install updated STC fitting on HPOP
Install updated screen for HPOP
In case you don't know, the 6.0 retains 3 to 4 qts. of existing oil when doing an oil change, therefore you will not be getting all of your additives out when you do the oil change/ flush.
Old 10-22-2012, 07:24 PM
2112's Avatar
Quote:
I did not know it was that much.
The only time I performed a Oil system flush using kinda similar additives, it did not end well. I have successfully removed water from a boat oil sump doing multiple changes of cheap oil tho. No additives tho diesel was recommended.
Old 10-22-2012, 07:55 PM
I don't think I would be interested in doing an oil system flush with anything but fresh oil .
Old 10-22-2012, 07:59 PM
Ah, ok. It seems like a good idea to not try and do a flush then.
I had no idea it was that much either.
Quote:
Makes sense now. I guess that's why I see almost nothing about doing oiling system flushes then.
Old 10-23-2012, 07:10 AM
So, are there any other oiling system "updated" parts I might be missing? I thought I read somewhere the dummy plugs and stand pipes were updated? Anything else?
Old 10-23-2012, 07:55 AM
69cj's Avatar
Fumoto drain valve on the oil pan. Saves a possible mess and your in total control.
Old 10-23-2012, 08:14 AM
Crash16 Crash16 is offline
Crash16 is gaining momentum as a positive member of FTE.
Don't forget updated stand pipes and dummy plugs.
Old 10-23-2012, 10:25 AM
Quote:
Added to list, thanks!
Let's keep it going! I am wanting to get the complete list so I can start ordering parts for the rebuild!
Old 10-23-2012, 02:17 PM
Misky6.0's Avatar
Misky6.0 Misky6.0 is online now
Misky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputation
I just replaced my turbo feed tube and oil pressure gauge (OPG).
I had to take the tube off to get to the OPG so I upgraded it.
If you have the braided feed tube, it's recommended you upgrade.
The OPG would frequently indicate no oil pressure and
make my "check gage" lite come on. My OPG sensor
wire was soaked with oil and it's a common problem with this gauge.
It was a PITA to get to this sensor once it's back on the engine.
it's only $30 at your local ford dealer.
Old 10-23-2012, 02:57 PM
I think that may have already been done on this truck but I will check into it for sure!
Old 10-24-2012, 10:07 PM
Bumping this up!
Cooling system maintenace/upgrades the_auto_tech 6.0L Power Stroke Diesel 46 02-02-2015 10:27 AM
Oiling system upgrades/maintenance the_auto_tech 6.0L Power Stroke Diesel 10 01-20-2015 09:47 AM
Finalizing maintenance and modifcation list before starting next project the_auto_tech 6.0L Power Stroke Diesel 43 10-13-2013 09:33 PM
Reviewing a few things before moving on - the_auto_tech 6.0L Power Stroke Diesel 49 08-02-2013 09:38 PM
Cooling system maintenance/modifications - the_auto_tech 6.0L Power Stroke Diesel 92 11-22-2012 10:03 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
