"F-150 OEM Filter and Fluid Specs
First post contains Fluid specs. 2nd Post contains Filter specs. Use Only Motorcraft Oil Filters and Transmission Filters. Air Filters; it is acceptable to use any brand. When it comes to engine oil filtes and transmission oil filters, nothing else can beat motorcraft. The engine and transmission will degrade faster with a non OEM filter. 3.5L V6 Turbo Engine Oil 6 Quarts 0W-30 / 5W-30 / 10W-30 Preferably 0W-30 or 5W-30 Transmission Oil 13.1 Quarts Mercon LV Coolant Fluid 16.5 Quarts Motorcraft Specalty Orange Coolant Rear Axle Oil 5.5 Pints or 2.75 Quarts 75W-140 Front Alxe Oil 3.5 Pints or 1.75 Quarts 75W-90 Transfercase Oil 1.6 Quarts Motorcraft Transfercase Fluid Any Mercon Transmission Fluid or form of Mercon works. For example III, V, SP, LV, or aftermarket. Brake Fluid DOT 3. DOT 4 can also be used. 3.7L V6 Engine Oil 6 Quarts 0W-20 / 5W-20 Transmission Oil 12.1 Quarts Mercon LV Coolant Fluid 16 Quarts Motorcraft Specalty Orange Coolant Rear Axle Oil 5.5 Pints or 2.75 Quarts 75W-140 Front Alxe Oil 3.5 Pints or 1.75 Quarts 75W-90 Transfercase Oil 1.6 Quarts Motorcraft Transfercase Fluid Any Mercon Transmission Fluid or form of Merconworks. For example III, V, SP, LV, or aftermarke. Brake Fluid DOT 3. DOT 4 can also be used. 5.0L V8 Engine Oil 7.7 Quarts 0W-20 / 5w-20 Transmission Oil 13.1 Quarts Mercon LV Coolant Fluid 17 Quarts Motorcraft Specalty Orange Coolant Rear Axle Oil 5.5 Pints or 2.75 Quarts 75W-140 Front Alxe Oil 3.5 Pints or 1.75 Quarts 75W-90 Transfercase Oil 1.6 Quarts Motorcraft Transfercase Fluid Any Mercon Transmission Fluid or form of Mercon works. For example III, V, SP, LV, or aftermarket. Brake Fluid DOT 3. DOT 4 can also be used. 6.2L V8 Engine Oil 7 Quarts 0W-20 / 5W-20 Transmission Oil 13.1 Quarts Mercon LV Powersteering Oil Mercon VCoolant Fluid 19.5 Quarts Motorcraft Specalty Orange Coolant Rear Axle Oil 5.5 Pints or 2.75 Quarts 75W-140 Front Alxe Oil 3.5 Pints or 1.75 Quarts 75W-90 Transfercase Oil 1.6 Quarts Motorcraft Transfercase Fluid Any Mercon Transmission Fluid or form of Mercon works. For example III, V, SP, LV, or aftermarket. Brake Fluid DOT 3. DOT 4 can also be used. 3.5L V6 Turbo Air Filter FA-1883 Oil Filter FL-500-S Transmission Pump Inlet FT-138 Transmission Internal Filter FT-188 3.7L V6 Air Filter FA-1883 Oil Filter FL-500-S Transmission Pump Inlet FT-138 Transmission Internal Filter FT-188 5.0L V8 Air Filter FA-1883 Oil Filter FL-500-S Transmission Pump Inlet FT-138 Transmission Internal Filter FT-188 6.2L V8 Air Filter FA-1883 Oil Filter FL-820-S Transmission Pump Inlet FT-138 Transmission Internal Filter FT-188 |
2009 - 2010
4.6L V2 V8 Engine Oil 6 Quarts 0W-20 / 5W-20 Coolant Fluid 16.4 Quarts Mortorcraft Premium Gold Engine Coolant Front Axle 3.5 Pints 75W-90 Rear Axle 8.8 / 9.75 5.5 Pints 75W-140 Powersteering Mercon V Transfercase Fluid 1.6 Quarts Motorcraft Transfercase Fluid. Any Mercon Transmission Fluid or form of Mercon works. For example III, V, SP, LV, or aftermarket. 4.6L V3 V8 Engine Oil 6 Quarts 0W-20 / 5W-20 Coolant Fluid 15.8 Quarts Mortorcraft Premium Gold Engine Coolant Front Axle 3.5 Pints 75W-90 Rear Axle 8.8 / 9.75 5.5 Pints 75W-140 Powersteering Mercon V Transfercase Fluid 1.6 Quarts Motorcraft Transfercase Fluid. Any Mercon Transmission Fluid or form of Mercon works. For example III, V, SP, LV, or aftermarket. 5.4L Engine Oil 7 Quarts 0W-20 / 5W-20 Coolant Fluid 16.9 Quarts Motorcraft Premium Gold Engine Coolant Front Axle 3.5 Pints 75W-90 Rear Axle 8.8 / 9.75 5.5 Pints 75W-140 Powersteering Mercon V Transfercase Fluid 1.6 Quarts Motorcraft Transfercase Fluid. Any Mercon Transmission Fluid or form of Mercon works. For example III, V, SP, LV, or aftermarket. Automatic Transmissions 2009 4R75E 13.9 Quarts Mercon LV 6R80 13.9 Quarts Mercon LV 2010 4R75E 4.6L V2 V8 13.9 Quarts 6R80 4.6L V3 V8 12.1 Quarts Mercon LV 6R80 5.4L V8 13.1 Quarts Mercon LV 4.6L 2 Valve V8 Air Filter FA-1883Oil Filter FL-820-S 4.6L 3 Valve V8 Air Filter FA-1883 Oil Filter FL-820-S 5.4L V8 Air Filter FA-1883 Oil Filter FL-820-S 2009-2010 Transmission Filters 4R75E FT-150 6R80 FT-171 FT-138 |
Great thread. Moving to the 2009+ F-150 forum for better exposure.
Nice post. Can it be made a sticky?
This could be helpful info since most people don't read their owners manual. :D
Originally Posted by juneau76
(Post 12370378)
I like it, but what about the 5.4 V8 Triton? Is it the same as the 5.0?
I will be adding the 2009 and 2010 soon. I just started with my year first.
I see, nice work, good stuff.
I updated the list. Let me know if I got something wrong.
Thanks for posting all the info...but I don't agree with your comment about Motorcraft filters. Wix and Hastings both make filters that trap a smaller particle than a regular Motorcraft.
moderating stickies
What is the difference on the 6R80 transmission filters? Non-tow vs. tow package?
Originally Posted by Phil Auten
(Post 16643581)
6R80 trans filters -2 filters, same trans?
What is the difference between the 2 filters listed? is one for the 4X2 and the other for the 4X4? Which is which?
