"F-150 OEM Filter and Fluid Specs - Ford Truck Enthusiasts Forums
Old 10-13-2012, 11:03 AM
smokersteve's Avatar
smokersteve smokersteve is offline
smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.
First post contains Fluid specs. 2nd Post contains Filter specs.
Use Only Motorcraft Oil Filters and Transmission Filters.
Air Filters; it is acceptable to use any brand.
When it comes to engine oil filtes and transmission oil filters, nothing else can beat motorcraft.
The engine and transmission will degrade faster with a non OEM filter.
3.5L V6 Turbo
Engine Oil
6 Quarts
0W-30 / 5W-30 / 10W-30
Preferably 0W-30 or 5W-30
Transmission Oil
13.1 Quarts
Mercon LV
Coolant Fluid
16.5 Quarts
Motorcraft Specalty Orange Coolant
Rear Axle Oil
5.5 Pints or 2.75 Quarts
75W-140
Front Alxe Oil
3.5 Pints or 1.75 Quarts
75W-90
Transfercase Oil
1.6 Quarts
Motorcraft Transfercase Fluid
Any Mercon Transmission Fluid or form of Mercon works. For example III, V, SP, LV, or aftermarket.
Brake Fluid
DOT 3.
DOT 4 can also be used.
3.7L V6
Engine Oil
6 Quarts
0W-20 / 5W-20
Transmission Oil
12.1 Quarts
Mercon LV
Coolant Fluid
16 Quarts
Rear Axle Oil
75W-140
Front Alxe Oil
75W-90
Transfercase Oil
1.6 Quarts
Any Mercon Transmission Fluid or form of Merconworks. For example III, V, SP, LV, or aftermarke.
Brake Fluid
DOT 3.
5.0L V8
Engine Oil
7.7 Quarts
0W-20 / 5w-20
Transmission Oil
13.1 Quarts
Mercon LV
Coolant Fluid
17 Quarts
Rear Axle Oil
75W-140
Front Alxe Oil
75W-90
Transfercase Oil
1.6 Quarts
Brake Fluid
DOT 3.
6.2L V8
Engine Oil
7 Quarts
0W-20 / 5W-20
Transmission Oil
13.1 Quarts
Mercon LV
Powersteering Oil
Mercon V
Coolant Fluid
19.5 Quarts
Rear Axle Oil
75W-140
Front Alxe Oil
75W-90
Transfercase Oil
1.6 Quarts
Brake Fluid
DOT 3.
3.5L V6 Turbo
Air Filter FA-1883
Oil Filter FL-500-S
Transmission Pump Inlet FT-138
Transmission Internal Filter FT-188
3.7L V6
Air Filter FA-1883
Oil Filter FL-500-S
5.0L V8
Air Filter FA-1883
Oil Filter FL-500-S
6.2L V8
Air Filter FA-1883
Oil Filter FL-820-S
Old 10-13-2012, 07:13 PM
2009 - 2010
4.6L V2 V8
Engine Oil
6 Quarts
0W-20 / 5W-20
Coolant Fluid
16.4 Quarts
Mortorcraft Premium Gold Engine Coolant
Front Axle
3.5 Pints
75W-90
Rear Axle 8.8 / 9.75
5.5 Pints
75W-140
Powersteering
Mercon V
Transfercase Fluid
1.6 Quarts
Motorcraft Transfercase Fluid.
4.6L V3 V8
Engine Oil
6 Quarts
0W-20 / 5W-20
Coolant Fluid
15.8 Quarts
Front Axle
3.5 Pints
75W-90
5.5 Pints
75W-140
Powersteering
Mercon V
Transfercase Fluid
1.6 Quarts
5.4L
Engine Oil
7 Quarts
0W-20 / 5W-20
Coolant Fluid
16.9 Quarts
Motorcraft Premium Gold Engine Coolant
Front Axle
3.5 Pints
75W-90
5.5 Pints
75W-140
Powersteering
Mercon V
Transfercase Fluid
1.6 Quarts
Automatic Transmissions
2009
4R75E
13.9 Quarts
Mercon LV
6R80
13.9 Quarts
Mercon LV
2010
4R75E 4.6L V2 V8
13.9 Quarts
6R80 4.6L V3 V8
12.1 Quarts
Mercon LV
6R80 5.4L V8
13.1 Quarts
Mercon LV
4.6L 2 Valve V8
Air Filter FA-1883
Oil Filter FL-820-S
4.6L 3 Valve V8
Air Filter FA-1883
Oil Filter FL-820-S
5.4L V8
Air Filter FA-1883
Oil Filter FL-820-S
2009-2010
4R75E
FT-150
6R80
FT-171
FT-138
Old 10-13-2012, 10:41 PM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
Great thread. Moving to the 2009+ F-150 forum for better exposure.
Old 10-14-2012, 05:14 AM
juneau76's Avatar
juneau76 juneau76 is offline
juneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud of
Nice post. Can it be made a sticky?
Old 10-14-2012, 07:03 AM
NASSTY's Avatar
NASSTY NASSTY is offline
NASSTY has a great reputation on FTE.NASSTY has a great reputation on FTE.NASSTY has a great reputation on FTE.NASSTY has a great reputation on FTE.NASSTY has a great reputation on FTE.NASSTY has a great reputation on FTE.
This could be helpful info since most people don't read their owners manual.
Old 10-14-2012, 07:28 AM
tseekins's Avatar
Quote:
As you wish sir.
Old 10-17-2012, 07:28 PM
MZEMS2 MZEMS2 is offline
MZEMS2 is starting off with a positive reputation.
I like it, but what about the 5.4 V8 Triton? Is it the same as the 5.0?
Old 10-17-2012, 07:34 PM
I will be adding the 2009 and 2010 soon. I just started with my year first.
Old 10-17-2012, 07:58 PM
I see, nice work, good stuff.
Old 10-20-2012, 12:27 AM
I updated the list. Let me know if I got something wrong.
Old 02-11-2013, 03:23 PM
Turbo Dog's Avatar
Turbo Dog Turbo Dog is offline
Turbo Dog has a good reputation on FTE.Turbo Dog has a good reputation on FTE.Turbo Dog has a good reputation on FTE.
Thanks for posting all the info...but I don't agree with your comment about Motorcraft filters. Wix and Hastings both make filters that trap a smaller particle than a regular Motorcraft.
Old 09-20-2013, 09:48 AM
meborder's Avatar
meborder meborder is online now
meborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant futuremeborder has a brilliant future
moderating stickies
Old 10-13-2016, 12:47 PM
Phil Auten Phil Auten is offline
Phil Auten is starting off with a positive reputation.
What is the difference on the 6R80 transmission filters? Non-tow vs. tow package?
Old 10-14-2016, 05:09 AM
tseekins's Avatar
Quote:
Same transmission.
Old 10-17-2016, 11:49 AM
6R80 trans filters -2 filters, same trans?
What is the difference between the 2 filters listed? is one for the 4X2 and the other for the 4X4? Which is which?
o-ring under oil fill cap?? JimsRebel Ford Inline Six, 200, 250, 4.9L / 300 3 12-31-2011 08:36 PM
The Official April 2011 New Jersey Chat & BS Thread sddesigns New Jersey Chapter 3602 05-01-2011 11:31 AM
The Official June 2010 New Jersey Chat & BS Thread sddesigns New Jersey Chapter 1939 07-01-2010 12:37 AM
DIesel trucks at Englishtown NJ chrisd0610 General Diesel Discussion 2 07-22-2008 04:20 PM
Really Funny Jokes!! 76f350spercamprspeal General NON-Automotive Conversation 15 02-18-2008 05:14 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
