Carb. Power Valve:
Does anyone know what size power valve it takes for an autolite 2100 carb. for a 1966 F-100 with 352 engine?Where can I just buy the valve without buying a complete kit? Thanks,Russ
There is a size stamped into the old power valve if you still have it, and most performance shops have a variety of replacements.
here are a few helpful links
the size will be stamped on the edge of the power valve it will be a two digit number such as 65... which stands for 6.5 hg of Vacuum that is the most common size used http://www.holley.com/data/TechServi...wer_valves.pdf List: Holley Power Valves | O'Reilly Auto Parts |
Thanks, everyone.I checked my old power valve and it looks like 6.5 in a circle that looks like an 8 on it??? What does that mean? Also,the old power valve does not have a shoulder on it.
Originally Posted by leonharu
(Post 12325099)
Can you post a photo of it? I am hoping NumbersDummy will chime in, he will know where to get one if anyone will.... If it is a Holley manufactured part then it will be relatively easy. but if it is FOMOCO, or motorcraft, it might be a bit tougher. It might be that the Holley will fit though.. Seems to me when I rebuilt the original on my truck, that the Kit was indeed a Holley kit... I later swapped in the Edelbrock after a power build up, I couldn't see putting the old Carb on with an in effect all new engine... |
after a bit of research yes you can use the Holley power valve, which is what I thought was the case...
here is a link about the rebuild process for 2150 and 2100 carbs http://www.therangerstation.com/tech..._2150_carb.pdf |
Originally Posted by Jetcopterpilot
(Post 12325667)
If it is a Holley manufactured part then it will be relatively easy. COAZ-9A565-A .. Economizer (Power) Valve ~ 0-5,000 ft. (Motorcraft CE-74) / Obsolete CARPENTER NOS OBSOLETE PARTS in Concord NC has 2 = 800-476-9653 (Note: DC listed as C0AZ, not COAZ - same church, different pew). GREEN SALES CO. in Cincinnati OH has 12 = 800-543-4959. --------------------------------------------------------- This exact same economizer valve comes in the carb kit = Applications: ALL 1962/74 Passenger Cars/Trucks / 1966/74 Bronco / 1969/74 Econoline. D4AZ-9A586-A (replaced C2AZ-9A586-B) .. 2100 series Auto-Lite/Motorcraft 2V Carburetor Kit (Motorcraft CT-499-D) / Available from Ford. MSRP: $33.42 FTE sponsor tousleyfordparts.com price: $18.38 / Tousley Ford - White Bear Lake MN FTE sponsor horizonpartsguy.com price: $20.05 / Horizon Ford - Seattle (Tukwila) WA |
