Carb. Power Valve: - Ford Truck Enthusiasts Forums
Carb. Power Valve:
Old 09-30-2012, 08:23 PM
leonharu's Avatar
leonharu leonharu is offline
leonharu is starting off with a positive reputation.
Carb. Power Valve:
Does anyone know what size power valve it takes for an autolite 2100 carb. for a 1966 F-100 with 352 engine?Where can I just buy the valve without buying a complete kit? Thanks,Russ
Old 09-30-2012, 09:22 PM
Jetcopterpilot's Avatar
Jetcopterpilot Jetcopterpilot is offline
Jetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputationJetcopterpilot has a superb reputation
There is a size stamped into the old power valve if you still have it, and most performance shops have a variety of replacements.
Old 09-30-2012, 09:32 PM
here are a few helpful links
the size will be stamped on the edge of the power valve it will be a two digit number such as 65... which stands for 6.5 hg of Vacuum that is the most common size used
http://www.holley.com/data/TechServi...wer_valves.pdf
List: Holley Power Valves | O'Reilly Auto Parts
Old 09-30-2012, 10:18 PM
leonharu's Avatar
Thanks, everyone.I checked my old power valve and it looks like 6.5 in a circle that looks like an 8 on it??? What does that mean? Also,the old power valve does not have a shoulder on it.
Old 10-01-2012, 03:01 AM
Quote:
Can you post a photo of it? I am hoping NumbersDummy will chime in, he will know where to get one if anyone will.... If it is a Holley manufactured part then it will be relatively easy. but if it is FOMOCO, or motorcraft, it might be a bit tougher. It might be that the Holley will fit though.. Seems to me when I rebuilt the original on my truck, that the Kit was indeed a Holley kit... I later swapped in the Edelbrock after a power build up, I couldn't see putting the old Carb on with an in effect all new engine...
Old 10-01-2012, 03:18 AM
after a bit of research yes you can use the Holley power valve, which is what I thought was the case...
here is a link about the rebuild process for 2150 and 2100 carbs
http://www.therangerstation.com/tech..._2150_carb.pdf
Old 10-01-2012, 09:13 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
OP has a 2100 series Auto-Lite (Motorcraft) carburetor, so it's not a Holley part. Holley's were not factory installed on 1965/66 F100/350's with 352's.
COAZ-9A565-A .. Economizer (Power) Valve ~ 0-5,000 ft. (Motorcraft CE-74) / Obsolete
CARPENTER NOS OBSOLETE PARTS in Concord NC has 2 = 800-476-9653 (Note: DC listed as C0AZ, not COAZ - same church, different pew).
GREEN SALES CO. in Cincinnati OH has 12 = 800-543-4959.
This exact same economizer valve comes in the carb kit = Applications: ALL 1962/74 Passenger Cars/Trucks / 1966/74 Bronco / 1969/74 Econoline.
D4AZ-9A586-A (replaced C2AZ-9A586-B) .. 2100 series Auto-Lite/Motorcraft 2V Carburetor Kit (Motorcraft CT-499-D) / Available from Ford.
MSRP: $33.42
FTE sponsor tousleyfordparts.com price: $18.38 / Tousley Ford - White Bear Lake MN
FTE sponsor horizonpartsguy.com price: $20.05 / Horizon Ford - Seattle (Tukwila) WA
2150 Power Valve Cover replacement Rusty_S Fuel Injection, Carburetion & Fuel System 1 08-10-2016 07:49 PM
rebuilt carb floods thestinkyone 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 01-21-2014 08:25 AM
power valve check valve rockpile 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 07-19-2011 12:23 AM
Gasoline leaking past power valve threads? 71LTD390 Fuel Injection, Carburetion & Fuel System 2 10-05-2004 08:31 PM
Motorcraft 2150 Enrichment valve? Skagit Fuel Injection, Carburetion & Fuel System 3 11-05-2003 02:26 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
