lightning engine swap?
I have an 01 F150 5.4L that is running up in miles and was really wanting to add the super charger off the lightning onto my truck. My question is can a engine out of a lightning go into my truck with no other things needed or what else will i need to get?
Originally Posted by F150in4x4
(Post 12294853)
as far as what's needed to make an eaton work on a N/A F-150 you need to start with the madenterprise "list" |
I bought a complete wrecked ightning and put the upper part and all the accessories on mine , then I sold the remaining parts truck.
I knew I had all parts needed and just had my ecm reprogrammed. Best way In my opinion to do this setup. |
lighting's had forged cranks and pistons i believe. Rods where the same.
You dont need either to to a L swap though. Just the intake,charger, and accessories. |
Wiring harness, ECU, GEM, Lower intake, upper intake, blower, All the EGR set up , Inner cooler, Radiator for inner cooler, inner cooler pump, hoses, throttle body,CAI, Etc. , Etc. Find a wreck and swap...
Ok I have a question here, why is it in order to do a lightning swap the ECM and wiring harness are needed? If the engine and everything is the same and lets say the IC parts are sourced through the after market could the swap be done with just the brackets pulleys and supercharger? Would it not be the same like when kenne bell was selling supercharger kits for the f150 and expedition. I ask because a friend found a HD engine for me for cheap but all it is, is the engine with all pullies and brackets but no computer or IC stuff. My F250 LD already has an E4OD so really I believe I just need the new style heads and the pulley bracket bolts since I plan on going with a MP pulley bracket and Whipple 3.4 of my buddies old engine.
Originally Posted by RedDragon777
(Post 12706356)
(Post 12706356)
The fuel system i am going to see if a member from the S197 forums can mod my current fuel set up with a walbro 400 and the trans i was already saving to have sent out to BTS to get beefed up. So would the rods be the only problem? Did the F250LD get anything different in the engine or is it the exact same as the Harley engine. I plan to keep and rebuild my current engine if possible. My truck has 125,000 miles on it where that Harley motor has close to 160,000.
(Post 12707790)
Edit: Found the list of what you need http://www.madenterprise.com/scparts.htm Mike is good ppl with great customer service. You dont have to buy from him but the list gives you an idea of what you will need. |
Originally Posted by Pili
(Post 12707128)
That harley motor has the same weak rods as every 5.4 has. And honestly the second you get into boost with that 3.4 you will have 8 holes in the sides of the block. Since the info needed is not here. i would suggest checking out lightningrodder.com, lightninggarage.com, or nloc.net. If you were serious about using that whipple i would have at least 15k put aside for a built long block, built trans, fuel system, ect.
Originally Posted by coopdagook
(Post 13224624)
I have a 93L and I'm a member at nloc.net, check them out, when it comes to boosted trucks, these guys know it all...
Lightning Garage is starting to over shadow NLOC with Gen 1 stuff (the records on NLOC are there though) and Lightning Garage and Lightning Rodder are the sites for Gen2 / Harley related stuff *EDIT* anyone who insist the ECM needs to be swapped over is a moron and should be ignored, as the 4r100 ECM won't operate a 4r70 transmission... |
