Drivetrain slack?
Does anyone else have what feels like drivetrain slack? Any cure? Im tired of all the clunking.
No slack or clunking on mine. Does the clunking occur when you are going from acceleration to deceleration and vice/versa?
Yep it does.
When I put my truck in park and take my foot off the brake it seems like it rolls a good 6 inches, drives me crazy.
I have it. Had the dealer check it and they said everything was tight. Bull. I'm going to gripe and have them check again. Towed my fw this week and it would even clunk changing gears sometimes. Something is wrong.
Originally Posted by stro1965
(Post 11979838)
That's why the vehicle is equipped with a parking brake ... it is to be used EVERY TIME you park the vehicle.
It's not an "Emergency Brake" ... I'm not even sure what good it is in an emergency. |
Originally Posted by screwy
(Post 11979039)
Not alot of things it could be - - U-joints - Most likely - Transmission - Not likely - Rearend - Possible but not as likely as U-joints. |
Originally Posted by Andrew010
(Post 11980465)
- U-joints - Most likely - Transmission - Not likely - Rearend - Possible but not as likely as U-joints. Bad U-Joint - YouTube 10 characters |
Originally Posted by SavageNFS
(Post 11980482)
this
10 characters Look at you, Johnny on the spot with the videos! |
I was looking it up when you posted...still pretty strange to have a u-joint go so quick, but there's always a chance for a defective one.
Great minds think alike I suppose.
(Post 11980500)
ten characters |
Fords drivelines have notoriously clunked over the years, the splines on the slip yoke may need to be greased (regreased) with this stuff:
Motorcraft XG8 PTFE Lubricant (Amazon $7) Procedure can be found here: 2004 F250 Slip Yoke Service |
Originally Posted by TRENT310
(Post 11980383)
