Drivetrain slack? - Ford Truck Enthusiasts Forums
Drivetrain slack?
Old 06-21-2012, 06:32 PM
screwy's Avatar
screwy screwy is offline
screwy has a good reputation on FTE.screwy has a good reputation on FTE.
Drivetrain slack?
Does anyone else have what feels like drivetrain slack? Any cure? Im tired of all the clunking.
Old 06-21-2012, 07:02 PM
Davgt500's Avatar
Davgt500 Davgt500 is offline
Davgt500 has a good reputation on FTE.Davgt500 has a good reputation on FTE.
No slack or clunking on mine. Does the clunking occur when you are going from acceleration to deceleration and vice/versa?
Old 06-21-2012, 09:24 PM
screwy's Avatar
Yep it does.
Old 06-21-2012, 09:33 PM
stro1965 stro1965 is offline
stro1965 is starting off with a positive reputation.
When I put my truck in park and take my foot off the brake it seems like it rolls a good 6 inches, drives me crazy.
Old 06-21-2012, 09:34 PM
myred1 myred1 is offline
myred1 is starting off with a positive reputation.
I have it. Had the dealer check it and they said everything was tight. Bull. I'm going to gripe and have them check again. Towed my fw this week and it would even clunk changing gears sometimes. Something is wrong.
Old 06-21-2012, 09:38 PM
2ndStroke's Avatar
2ndStroke 2ndStroke is offline
2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation
Quote:
lol wife guided me into load up her sled at the shop last winter, guided me right up, 2inches away from the ramp. Tailgate was down, put it in park, took my foot off the brake and BAM! ...Drives me crazy too
Old 06-21-2012, 11:01 PM
TRENT310's Avatar
TRENT310 TRENT310 is offline
TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.
That's why the vehicle is equipped with a parking brake ... it is to be used EVERY TIME you park the vehicle.
It's not an "Emergency Brake" ... I'm not even sure what good it is in an emergency.
Old 06-21-2012, 11:17 PM
Andrew010's Avatar
Andrew010 Andrew010 is offline
Andrew010 has a good reputation on FTE.Andrew010 has a good reputation on FTE.
Quote:
Not alot of things it could be -
- U-joints - Most likely
- Transmission - Not likely
- Rearend - Possible but not as likely as U-joints.
Old 06-21-2012, 11:21 PM
SavageNFS's Avatar
SavageNFS SavageNFS is online now
not a WHITE truck
SavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputation
this
Bad U-Joint - YouTube
10 characters
Old 06-21-2012, 11:23 PM
Andrew010's Avatar
Quote:
Originally Posted by SavageNFS View Post
this
10 characters
Look at you, Johnny on the spot with the videos!
Old 06-21-2012, 11:24 PM
SavageNFS's Avatar
not a WHITE truck
I was looking it up when you posted...still pretty strange to have a u-joint go so quick, but there's always a chance for a defective one.
Old 06-21-2012, 11:27 PM
Andrew010's Avatar
Great minds think alike I suppose.
Old 06-21-2012, 11:28 PM
SavageNFS's Avatar
not a WHITE truck
ten characters
Old 06-22-2012, 06:41 AM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold
Fords drivelines have notoriously clunked over the years, the splines on the slip yoke may need to be greased (regreased) with this stuff:
Motorcraft XG8 PTFE Lubricant (Amazon $7)
Procedure can be found here:
2004 F250 Slip Yoke Service
Old 06-22-2012, 09:41 AM
Lastwagen's Avatar
Lastwagen Lastwagen is offline
Lastwagen is starting off with a positive reputation.
The parking/emergency brake is a cable connection to the rear wheel brakes. Everything is separate from the hydraulic braking system so that if the hydraulic system fails you would still have the "emergency brakes" which would be a little better than "no brakes".
Drivetrain slop 09f250v10 6.7L Power Stroke Diesel 9 08-22-2016 07:51 PM
Drivetrain Slack Clunking screwy 1999 to 2016 Super Duty 21 05-07-2016 06:29 PM
2012 F250 Drivetrain Noise F350Man79 1999 to 2016 Super Duty 1 12-30-2015 09:53 PM
Drivetrain Slack at Highway speeds BCHauler 1997 - 2003 F150 7 05-15-2014 07:23 AM
odd clunking noises Monsta Excursion - King of SUVs 22 11-14-2011 05:33 PM
Tags
2009, f150, forums, jumps, lariat, park, put, slack, supercrew, truck, ujoint
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
