Ford Truck Enthusiasts Forums
-   Flathead V8 & Flathead 6 (https://www.ford-trucks.com/forums/forum57/)
-   -   (((((how much oil in the fan??))))) (https://www.ford-trucks.com/forums/1159831-how-much-oil-in-the-fan.html)
billb2000 05-04-2012 08:38 PM
got a 47 ford truck ,I need to know what weight and how much oil to put in that cup behind the fan blade ,thanks guys!!!
fixnair 05-04-2012 11:44 PM
I would use the same oil as in your crankcase.
f5fordgirl 05-06-2012 04:14 PM
Use 85-90 gear oil, and fill it half full.
greenmachinejohn 05-07-2012 06:26 PM
This is from a F Series Operators manual Printed July 19, 1949. Maintenance fan- 5,000 miles. Turn fan until plug is at the top. Remove plug and add 1oz. *ENGINE OIL. Turn fan until hole is at bottom to drain excess oil. Install Plug.
Inside the fan is tube around the plug that will only leave a certain amount of oil inside the fan, when the plug is the down position. There is 2 gaskets that are $2 a piece. Can send pictures if interested. Just rebuilt one for my truck.
