Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-04-2012, 08:38 PM
billb2000 billb2000 is offline
Garage is empty, add now
billb2000 is starting off with a positive reputation.
(((((how much oil in the fan??)))))
got a 47 ford truck ,I need to know what weight and how much oil to put in that cup behind the fan blade ,thanks guys!!!
  #2 (permalink)
Old 05-04-2012, 11:44 PM
fixnair's Avatar
fixnair fixnair is offline
fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.fixnair has a very good reputation on FTE.
fixnair
I would use the same oil as in your crankcase.
__________________
2002 F350 7.3 Ltr. 6sp.DRW 270K miles, 13' service body
1952 F1 flathead Project Truck
2008 Lincoln MKX
need thermostat housing & cab 4 project
  #3 (permalink)
Old 05-06-2012, 04:14 PM
f5fordgirl f5fordgirl is offline
f5fordgirl is starting off with a positive reputation.
Use 85-90 gear oil, and fill it half full.
  #4 (permalink)
Old 05-07-2012, 06:26 PM
greenmachinejohn's Avatar
greenmachinejohn greenmachinejohn is offline
2000 Ford F-350
My Garage
greenmachinejohn is gaining momentum as a positive member of FTE.
toeheadproductions@ymail.com
This is from a F Series Operators manual Printed July 19, 1949. Maintenance fan- 5,000 miles. Turn fan until plug is at the top. Remove plug and add 1oz. *ENGINE OIL. Turn fan until hole is at bottom to drain excess oil. Install Plug.
Inside the fan is tube around the plug that will only leave a certain amount of oil inside the fan, when the plug is the down position. There is 2 gaskets that are $2 a piece. Can send pictures if interested. Just rebuilt one for my truck.
__________________
John
1950 Ford F-1 Flathead V-8
1968 Ford F-100 Base 390 4Bl
390 Crank and Rods, Stage 1 Cam, 66' Fairlane intake, Floor Shift, Headers, 3" Glasspacks, Torsen Differential
2000 Ford F-350 XLT V10Morosso Spiral-Flow
1957 Little Gem 17' Camper
Tags
1950, flathead, ford, oil, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
