Dash Noise 2008 Expedition
I have been experiencing some intermittent noise emanating from the driver's side dash closest to the center of the car. I have tried turning off the climate control system and radio but the noise persists. It occurs while driving and when stopped. It sounds like clicking with about a half second frequency.
I have not yet taken it in due to its intermittent behavior. The noise began last year when the vehicle had about 72,000 miles. It now has 77,000. Any ideas? Thanks, James Dillis |
Mine does the samething. Wish I knew what it was.
Mine makes the same soft clicking noise. (08 F250)
I had a rattle that came for both front ducts.....found it was my sun glasses in the overhead consule! |
Does the noise happen only when the car is in motion? Engine on?
Originally Posted by berry1234
(Post 11685971)
I've tried every combination of the ac/heat fan controls, radio, CD, on/off ect. It's a faint tapping/ticking near the center of the dash, has a somewhat random pattern of 2 sec taps. |
Strange! Possibly a vent door that can't close? I would play with the vent settings-floor-dash, etc and see if you can make it worse/better so you could explain it to the shop.
Having the same problem with my 2007 Expedition EL EB 4x4 with 159,000 miles. Seems to have something to do with AC, however I do hear it even with the AC turned off as well as if I turn the AC off while it's making the clicking noise. Maybe something to do with the fan that draws in outside air? I'm pulling at strings as well as pulling my hair out some days with that clicking noise. Did you ever find a solution to yours?
