Engine Swap 05 F250 5.4 V8
Hay,
I new to all of this and I am not a master mechanic. i can do regular maintenance and that is about it. I been looking for a cheap truck. I found a 2005 F250 Crew Cab it has a blown motor 5.4V8. It is for sale for $2000 obo. I have been looking online and I wanted to put a 460 big block in but I have decided to go with a 427 stroker small block. I figured it would be easier to swap out and I should be able to use the stock transmission. How easy would the swap be? Now the truck has 180,000 miles on it so maybe I should get a new transmission? What is your opinions of my idea how do you think it will run? I am not to concern with mileage but what do think it would get. |
What is going to control the transmission?
I don't think this would be an easy swap, why not buy a built up 5.4 ? |
You'll definitely have your hands full with this swap. You'd need a stand-alone controller for the transmission for sure. If you change transmissions, then you'll likely be getting into changing the length of the driveshaft (driveshafts if it's a 4x4). Then you'll have to get the gauges working and all.
Where do you live? If you live in a state that does emissions checks, you may never be able to get it legal to operate on the roads. Keep in mind too that if you don't follow the project through to the finish (including making sure everything works) that your resale value will be pretty much wiped out. You're buying a truck with a blown motor for $2K, but once you start hacking the wires, you'd be lucky to even hold that value unless you finish it right. I'm by no means trying to discourage you. Just realize what you're getting into! |
The stock transmission won't bolt to a small block. It won't bolt to a big block, either. It will only bolt to a Modular engine such as the 5.4L.
Not sure why you would want to swap one of those into this truck The 3V 5.4 has more power than even a 460 and gets better gas mileage.
If anything, I would look into doing a Cummins swap. Otherwise, just replace it with another 3V 5.4. |
Taking out the old 5.4 motor, and replacing it with another 5.4 motor is really an easy job. At that price, you could buy the truck, find a decent used motor, swap them out, keep it or even flip it for a profit. Heck, where is this truck, if that's all that's wrong with it, I might even buy it myself if you decide you don't want it. Good luck.
I second the Cummins swap. That is what mine will get when my 5.4 finally bites the bullet.
Originally Posted by shaneinga
(Post 11648765)
It's hard enough swapping a cummins into a truck that is already diesel!!! Whats wrong with the modular engines? They are better than older engines in many, many ways! You make it sound like they're disposable, when in reality these modular engines simply ROCK :-jammin |
5.4L
Originally Posted by Mark Kovalsky
(Post 11646664)
buld up a 5.4 Haaaa
Originally Posted by parkland
(Post 11645720)
You do realize that you have replied to a 5 1/2 year old zombie thread...right?
yes I do but I recently bought (with great remorse) this truck.
how do I get to the more modern threads
Originally Posted by 69th soldier
(Post 17541860)
