Engine Swap 05 F250 5.4 V8 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-30-2012, 02:08 PM
checkeredflag55 checkeredflag55 is offline
checkeredflag55 is starting off with a positive reputation.
Hay,
I new to all of this and I am not a master mechanic. i can do regular maintenance and that is about it. I been looking for a cheap truck. I found a 2005 F250 Crew Cab it has a blown motor 5.4V8. It is for sale for $2000 obo. I have been looking online and I wanted to put a 460 big block in but I have decided to go with a 427 stroker small block. I figured it would be easier to swap out and I should be able to use the stock transmission. How easy would the swap be? Now the truck has 180,000 miles on it so maybe I should get a new transmission? What is your opinions of my idea how do you think it will run? I am not to concern with mileage but what do think it would get.
Old 03-30-2012, 03:02 PM
parkland parkland is offline
parkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud of
What is going to control the transmission?
I don't think this would be an easy swap, why not buy a built up 5.4 ?
Old 03-30-2012, 07:13 PM
Psyclopse's Avatar
Psyclopse Psyclopse is offline
Psyclopse has a great reputation on FTE.Psyclopse has a great reputation on FTE.Psyclopse has a great reputation on FTE.Psyclopse has a great reputation on FTE.Psyclopse has a great reputation on FTE.
You'll definitely have your hands full with this swap. You'd need a stand-alone controller for the transmission for sure. If you change transmissions, then you'll likely be getting into changing the length of the driveshaft (driveshafts if it's a 4x4). Then you'll have to get the gauges working and all.
Where do you live? If you live in a state that does emissions checks, you may never be able to get it legal to operate on the roads. Keep in mind too that if you don't follow the project through to the finish (including making sure everything works) that your resale value will be pretty much wiped out. You're buying a truck with a blown motor for $2K, but once you start hacking the wires, you'd be lucky to even hold that value unless you finish it right.
I'm by no means trying to discourage you. Just realize what you're getting into!
Old 03-30-2012, 07:37 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is online now
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
The stock transmission won't bolt to a small block. It won't bolt to a big block, either. It will only bolt to a Modular engine such as the 5.4L.
Old 03-30-2012, 09:40 PM
kd0axs's Avatar
kd0axs kd0axs is offline
kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.
Not sure why you would want to swap one of those into this truck The 3V 5.4 has more power than even a 460 and gets better gas mileage.
If anything, I would look into doing a Cummins swap. Otherwise, just replace it with another 3V 5.4.
Old 03-31-2012, 08:08 AM
brd7666's Avatar
brd7666 brd7666 is offline
brd7666 has a very good reputation on FTE.brd7666 has a very good reputation on FTE.brd7666 has a very good reputation on FTE.
Taking out the old 5.4 motor, and replacing it with another 5.4 motor is really an easy job. At that price, you could buy the truck, find a decent used motor, swap them out, keep it or even flip it for a profit. Heck, where is this truck, if that's all that's wrong with it, I might even buy it myself if you decide you don't want it. Good luck.
Old 03-31-2012, 08:21 AM
shaneinga shaneinga is offline
shaneinga is starting off with a positive reputation.
I second the Cummins swap. That is what mine will get when my 5.4 finally bites the bullet.
Old 03-31-2012, 12:32 PM
Quote:
You guys make that sound like it would be sooo easy!!!
It's hard enough swapping a cummins into a truck that is already diesel!!!
Whats wrong with the modular engines? They are better than older engines in many, many ways! You make it sound like they're disposable, when in reality these modular engines simply ROCK
5.4 Fuel Injection in Classic Help Daniels54 Modular V8 (4.6L, 5.4L) 0 10-31-2016 09:02 PM
06 F-250 5.4 - Diesel Swap? 5_Slow 1999 to 2016 Super Duty 4 09-27-2016 09:00 AM
6.2 ZF6 Swap? Menghi08LT 6.2L V8 9 01-01-2016 01:35 AM
5.4 2v to 3v swap 907fordfanatic 1999 to 2016 Super Duty 6 02-01-2012 10:03 PM
5.4 to 7.3 motor swap bktaylor1217 1999 to 2016 Super Duty 9 12-02-2010 07:24 PM
Tags
05, 2005, 54, 62, 68, blown, cab, crew, diesel, engine, f250, ford, motor, removal, swap, swaps
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
