2002 F150 Wiring Diagram NEEDED
02 f-150 4.6 supercrew 2wd xlt auto
Replaced the heater core, reassembled dash, forgot two plugs to the instrument cluster, removed necessary items, replaced plugs and reassembled the dash to factory specs. Attempt to START= starter engaged normal speed/no start. Ignition in the ON position = Gauges do not clock over/indicators DO function. Theft light is NO different than pre-H.C. replacement. Possible PATS ?? (removed ignition tumbler to remove column cover) reinstalled. All fuses in the underhood and dash are good. I would like direction to a wiring diagram for the ignition system/fuel system/instrument cluster-pin locations/funtions and If there is anyone with information or a diagram regarding the Ford Vehicle Security used as an alarm piggybacking the factory keyless entry system, I need the functions and possible programming info. |
sorry so late, Im new and I just saw your message, Do you still need the diagram ? I have all service info from 2000-2003 and some 2004 for all fords
He posted once and never returned in two months...
Move on. |
Ok.. Thanks
Hey Locksmith1 - I have an 2003 F150. Is it possible you can share me the wiring diagrams you have. I have a weird problem that started after installing a remote starter. Any information would be greatly appreaciated. I'm the original owner and plan on keep my truck for a long, long time. Thanks. Dan
What is the prob ?
There are alot if diagrams for your truck, I assume you looking for the starter system ? Let me know what you need and your email address, I'll send then over Friday after work.
yes.. mainly the starting system and any information on the PATS system if you have. Thanks: phyrelizard@yahoo.com
Sorry just got back from vacation, I'll send over asap
Tried to copy and paste the diagrams that I selected for you. But, for some reason I am unable, I think the software wont allow it. Anyway, Please post your email address and I will email them to you.
Ok.. you can just send it to phyrelizard@yahoo.com. thanks again!
I'll send after work tonight
Sorry for delay, got held up...Sending now
Check Email.. Just sent you a boat load of diagrams. If you need more let me know
Im looking for a 01 f250 v10 diagram to install a security/start system
