2002 F150 Wiring Diagram NEEDED
Old 03-21-2012, 03:11 AM
oddcompany's Avatar
oddcompany
oddcompany is offline
Exclamation 2002 F150 Wiring Diagram NEEDED
02 f-150 4.6 supercrew 2wd xlt auto
Replaced the heater core, reassembled dash, forgot two plugs to the instrument cluster, removed necessary items, replaced plugs and reassembled the dash to factory specs. Attempt to START= starter engaged normal speed/no start. Ignition in the ON position = Gauges do not clock over/indicators DO function. Theft light is NO different than pre-H.C. replacement. Possible PATS ?? (removed ignition tumbler to remove column cover) reinstalled. All fuses in the underhood and dash are good.
I would like direction to a wiring diagram for the ignition system/fuel system/instrument cluster-pin locations/funtions and If there is anyone with information or a diagram regarding the Ford Vehicle Security used as an alarm piggybacking the factory keyless entry system, I need the functions and possible programming info.
Old 05-20-2012, 10:53 PM
Locksmith1's Avatar
Locksmith1
Locksmith1 is offline
sorry so late, Im new and I just saw your message, Do you still need the diagram ? I have all service info from 2000-2003 and some 2004 for all fords
Old 05-21-2012, 06:35 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
He posted once and never returned in two months...
Move on.
Old 05-21-2012, 07:46 AM
Locksmith1's Avatar
Locksmith1
Ok.. Thanks
Old 05-23-2012, 06:29 PM
Phyrelizard's Avatar
Phyrelizard
Phyrelizard is offline
Hey Locksmith1 - I have an 2003 F150. Is it possible you can share me the wiring diagrams you have. I have a weird problem that started after installing a remote starter. Any information would be greatly appreaciated. I'm the original owner and plan on keep my truck for a long, long time. Thanks. Dan
Old 05-24-2012, 06:57 AM
Locksmith1's Avatar
Locksmith1
What is the prob ?
Old 05-24-2012, 07:36 AM
Locksmith1's Avatar
Locksmith1
There are alot if diagrams for your truck, I assume you looking for the starter system ? Let me know what you need and your email address, I'll send then over Friday after work.
Old 05-26-2012, 01:16 PM
Phyrelizard
yes.. mainly the starting system and any information on the PATS system if you have. Thanks: phyrelizard@yahoo.com
Old 05-30-2012, 08:19 AM
Locksmith1's Avatar
Locksmith1
Sorry just got back from vacation, I'll send over asap
Old 05-31-2012, 06:09 PM
Locksmith1's Avatar
Locksmith1
Tried to copy and paste the diagrams that I selected for you. But, for some reason I am unable, I think the software wont allow it. Anyway, Please post your email address and I will email them to you.
Old 05-31-2012, 10:53 PM
Phyrelizard
Ok.. you can just send it to phyrelizard@yahoo.com. thanks again!
Old 06-01-2012, 08:02 AM
Locksmith1's Avatar
Locksmith1
I'll send after work tonight
Old 06-03-2012, 08:29 PM
Locksmith1's Avatar
Locksmith1
Sorry for delay, got held up...Sending now
Old 06-03-2012, 08:50 PM
Locksmith1's Avatar
Locksmith1
Check Email.. Just sent you a boat load of diagrams. If you need more let me know
Old 05-27-2013, 01:59 PM
jimm.d.daniel's Avatar
jimm.d.daniel
jimm.d.daniel is offline
Im looking for a 01 f250 v10 diagram to install a security/start system
Quick Reply: 2002 F150 Wiring Diagram NEEDED
