Fuel Filter Change Interval
how often do you guys change your fuel filter?
thanks |
20K miles was recommended to me in another thread where I asked the same question.
Mike |
thanks:-X22
I change it with my oil change....
Originally Posted by Aune163rd
(Post 11548131)
Mike |
every 60,000 miles
Originally Posted by '94IDITurbo7.3
(Post 11547985)
thanks according to my 1993 diesel fuel supplement book (thank you ebay!) the chart for change intervals on the fuel filter is also 60k miles. all other places in the chart have "3" which states: more frequent intervals may be required dependent on fuel quality and vehicle usage.an instrument panel warning light will glow when servicing is required,or when the ignition key is in the START position. FYI; for the interval of draining the water fuel bowl (1993 diesel fuel supplement) has an X checked in all of the mile intervals.which means every 5k miles.it also shares the "3". .......... so in summary; change the fuel filter at a MAX 60k miles.sooner if you get the light for that.that one simply reads "fuel filter" drain the bowl every 5k MAX.sooner if you see the light for that.that one reads "water in fuel" |
Originally Posted by FORDF250HDXLT
(Post 11548293)
the fuel filter should be replaced every 60,000 miles or 48 months.whichever comes first.according to haynes diesel tech book #10300.
you betcha.with these fuel filters costing $40-50,there's no point in replacing them needlessly.:-X22
(Post 11548539)
I replace mine once a year, mileage or not.
Your fuel filters cost 40-50 dollars??!!! I dont know what kind of fuel filter your buying...
And my oil change intervals are at 3k miles, idc if i am on the side of the road changing my oil, its 3k miles...i keep a full oil change in my IDI's at all times...
Here is a way for you to save money on these water seperators XD! :
Motorcraft FD3375 - Fuel Filter | O'Reilly Auto Parts |
Originally Posted by IDIDieselJohn
(Post 11548815)
