Fuel Filter Change Interval - Ford Truck Enthusiasts Forums
Old 03-08-2012, 05:27 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3 '94IDITurbo7.3 is offline
'94IDITurbo7.3 is gaining momentum as a positive member of FTE.
how often do you guys change your fuel filter?
thanks
Old 03-08-2012, 05:41 PM
whiteboyslo's Avatar
whiteboyslo whiteboyslo is offline
whiteboyslo is gaining momentum as a positive member of FTE.
20K miles was recommended to me in another thread where I asked the same question.
Mike
Old 03-08-2012, 05:55 PM
thanks
Old 03-08-2012, 06:09 PM
Aune163rd's Avatar
Aune163rd Aune163rd is offline
Aune163rd has a very good reputation on FTE.Aune163rd has a very good reputation on FTE.Aune163rd has a very good reputation on FTE.
I change it with my oil change....
Old 03-08-2012, 06:17 PM
Quote:
What's your interval on oil changes?
Mike
Old 03-08-2012, 06:46 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is online now
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
Post every 60,000 miles
Quote:
thanks
the fuel filter should be replaced every 60,000 miles or 48 months.whichever comes first.according to haynes diesel tech book #10300.
according to my 1993 diesel fuel supplement book (thank you ebay!) the chart for change intervals on the fuel filter is also 60k miles.
all other places in the chart have "3" which states:
more frequent intervals may be required dependent on fuel quality and vehicle usage.an instrument panel warning light will glow when servicing is required,or when the ignition key is in the START position.
FYI;
for the interval of draining the water fuel bowl (1993 diesel fuel supplement) has an X checked in all of the mile intervals.which means every 5k miles.it also shares the "3".
so in summary;
change the fuel filter at a MAX 60k miles.sooner if you get the light for that.that one simply reads "fuel filter"
drain the bowl every 5k MAX.sooner if you see the light for that.that one reads "water in fuel"
Old 03-08-2012, 07:05 PM
FYI;
so in summary;
thanks for the good info once again.
Old 03-08-2012, 07:23 PM
you betcha.with these fuel filters costing $40-50,there's no point in replacing them needlessly.
Old 03-08-2012, 07:42 PM
were do you get your filters from? i get mine from a-zone. the two that i have used since i got my truck have been fine. not had any problems. cost ~$15.00
Old 03-08-2012, 08:09 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
I replace mine once a year, mileage or not.
Old 03-08-2012, 08:23 PM
Aune163rd's Avatar
Your fuel filters cost 40-50 dollars??!!! I dont know what kind of fuel filter your buying...
Old 03-08-2012, 08:27 PM
Aune163rd's Avatar
And my oil change intervals are at 3k miles, idc if i am on the side of the road changing my oil, its 3k miles...i keep a full oil change in my IDI's at all times...
Old 03-08-2012, 08:28 PM
Aune163rd's Avatar
Here is a way for you to save money on these water seperators XD! :
Motorcraft FD3375 - Fuel Filter | O'Reilly Auto Parts
Old 03-08-2012, 08:29 PM
Aune163rd's Avatar
Old 03-08-2012, 08:39 PM
Quote:
that is what i have been doing since that is what the PO did. i change it in the fall so it is brand new for the winter months.
Fuel filter questions big315 6.0L Power Stroke Diesel 11 05-13-2016 01:08 PM
Filter change brother steve 6.7L Power Stroke Diesel 15 10-29-2015 02:24 PM
Fuel filter change required caere 6.7L Power Stroke Diesel 5 08-12-2014 06:40 AM
Socket size fuel filter macguy 6.7L Power Stroke Diesel 5 11-30-2012 07:01 AM
Cabin Air Filter? fordtruck661 1999 - 2003 7.3L Power Stroke Diesel 4 10-22-2011 08:44 PM
Tags
73, change, diesel, escape, f250, filter, ford, fuel, interval, intervals, microgard, oul, recomended, replacement, truck, warning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
