__08 F350 CC 4X4 Diesel. Upgrades? MPG?
22K miles
35" tires MPG stinks... Not looking to spend more than a thousand or so at most. |
What are you getting for MPG?
The 6.4 isn't known for great mileage. |
12.. eh I tell you its enough (lack of) to make me a non believer :'(
Moved to the 6.4L Power Stroke Diesel forum.
drop the tires back down to stock for one. Watch your speeds and try to take off slower and coast. Keep rpms below 2K and stay off the boost.
Other issue maybe 4 tons of mass in stop and go traffic..takes a considerable amount of fuel. |
Originally Posted by Musher
(Post 11455648)
22K miles
35" tires MPG stinks... Not looking to spend more than a thousand or so at most. Are you using Cetane booster? Ive heard that will give you a little bit. |
I feel like I'm walkin on eggshells to get a little decent fuel milage as it is....Very little difference on heavy foot or light foot. I might get an extra mile on the open HWY... and I at least want some 35's on it also.
Originally Posted by senix
(Post 11457722)
You don't say what the rear axle is but with the 35s and a 4x4 12 MPG is about what you should expect, that's just the nature of the truck. There are some gains available with mods but your stated budget makes the selection pretty slim. I think you can get a tuner called DPF Delete (maybe DPF-R) or something like that for around 500 buckaroos and a delete pipe for maybe 250 bucks. Check on ebay for prices just put in the truck info and "DPF delete" and get the current prices. Use the other 250 to buy enough beer to get you in a mood where you can part with the 35s. Do all that and you might get 2 MPG better on average. Sorry, but that's the situation.
(Post 11457722)
Axle is 3.73
It sounds like 12 mpg is about it with this truck. I'm sure I could spend several thousand with intake and exhaust to get another mile or two maybe. Are there not cosequences to the system with a "DPF" delete? Are other programmers any benifit to this motor? |
I can get 14 stock and 17 ish with the banks.
(Post 11461434)
Axle is 3.73
It sounds like 12 mpg is about it with this truck. I'm sure I could spend several thousand with intake and exhaust to get another mile or two maybe. Are there not cosequences to the system with a "DPF" delete? Are other programmers any benifit to this motor? My truck is a 4.30 with DRWs. I deleted for less than your stated budget. Bought a used tuner from Craigs and a pipe from ebay. $600 plus I had to buy a sensor beecause I couldn't get one out of the old pipe. I don't have a lot of data yet but I'm getting 10 MPG towing on three trips, a 1 to 1.5 MPG increase. On my last check of mixed driving half highway half city I got 14.3 and that's the best I've ever done. Again a 1 to 2 MPG increase. That's probably the best I'm gonna get but you should do better with a 3.73. I think given where the price of diesel is going a 10 or 15 percent gain might be worth it. |
