__08 F350 CC 4X4 Diesel. Upgrades? MPG? - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 02-19-2012, 10:51 AM
Musher Musher is offline
Musher is starting off with a positive reputation.
22K miles
35" tires
MPG stinks...
Not looking to spend more than a thousand or so at most.
Old 02-19-2012, 11:05 AM
kd0axs's Avatar
kd0axs kd0axs is offline
kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.
What are you getting for MPG?
The 6.4 isn't known for great mileage.
Old 02-19-2012, 02:59 PM
12.. eh I tell you its enough (lack of) to make me a non believer
Old 02-19-2012, 05:14 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the 6.4L Power Stroke Diesel forum.
Old 02-19-2012, 06:05 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
drop the tires back down to stock for one. Watch your speeds and try to take off slower and coast. Keep rpms below 2K and stay off the boost.
Other issue maybe 4 tons of mass in stop and go traffic..takes a considerable amount of fuel.
Old 02-19-2012, 06:10 PM
captainkbt captainkbt is offline
captainkbt is starting off with a positive reputation.
Quote:
Originally Posted by Musher View Post
22K miles
35" tires
MPG stinks...
Im assuming you mean 22K miles per year because if you mean total miles on your PSD, I wouldnt even worry about it......because you dont drive it enough.
Are you using Cetane booster? Ive heard that will give you a little bit.
Old 02-19-2012, 08:00 PM
I feel like I'm walkin on eggshells to get a little decent fuel milage as it is....Very little difference on heavy foot or light foot. I might get an extra mile on the open HWY... and I at least want some 35's on it also.
Old 02-19-2012, 08:21 PM
StanleyZ's Avatar
StanleyZ StanleyZ is offline
StanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to beholdStanleyZ is a splendid one to behold
You don't say what the rear axle is but with the 35s and a 4x4 12 MPG is about what you should expect, that's just the nature of the truck. There are some gains available with mods but your stated budget makes the selection pretty slim. I think you can get a tuner called DPF Delete (maybe DPF-R) or something like that for around 500 buckaroos and a delete pipe for maybe 250 bucks. Check on ebay for prices just put in the truck info and "DPF delete" and get the current prices. Use the other 250 to buy enough beer to get you in a mood where you can part with the 35s. Do all that and you might get 2 MPG better on average. Sorry, but that's the situation.
Old 02-19-2012, 10:38 PM
auriferous auriferous is offline
auriferous is gaining momentum as a positive member of FTE.
Thumbs up
staying off the boost is wise and 65-70 mph tops .I did a trip 220 miles R/T used 12 gals. and was followin the boost advice hope to repeat that more often [banks 6gun set on "econ"]
Old 02-20-2012, 12:35 PM
Axle is 3.73
It sounds like 12 mpg is about it with this truck.
I'm sure I could spend several thousand with intake and exhaust to get another mile or two maybe.
Are there not cosequences to the system with a "DPF" delete?
Are other programmers any benifit to this motor?
Old 02-20-2012, 01:13 PM
senix's Avatar
I can get 14 stock and 17 ish with the banks.
Old 02-20-2012, 03:39 PM
StanleyZ's Avatar
Axle is 3.73
You can do a bit better. I think Sennix has a 3.73 and he is DPF on with the banks. I don't think there is much down side to the Delete tuner with mild tunes. 50 HP or so. At least I don't recall anyone talking about them. Of course you lose the warranty if you have one. And it is a federal crime. And a PITA if you have to go back to stock for an emmissions inspection.
My truck is a 4.30 with DRWs. I deleted for less than your stated budget. Bought a used tuner from Craigs and a pipe from ebay. $600 plus I had to buy a sensor beecause I couldn't get one out of the old pipe. I don't have a lot of data yet but I'm getting 10 MPG towing on three trips, a 1 to 1.5 MPG increase. On my last check of mixed driving half highway half city I got 14.3 and that's the best I've ever done. Again a 1 to 2 MPG increase. That's probably the best I'm gonna get but you should do better with a 3.73. I think given where the price of diesel is going a 10 or 15 percent gain might be worth it.
2009 f150 MPG brent1204 2009 - 2014 F150 7 02-14-2014 11:57 AM
5.4 owners What's your MPG??? jerem0621 2004 - 2008 F150 19 12-31-2012 10:08 PM
callibrating mpg gauge? jyarosz 2009 - 2014 F150 4 06-29-2012 10:31 PM
Crew cab mpg differences. 2wd vs 4wd jake00 2004 - 2008 F150 7 05-09-2012 04:14 PM
21 Mpg. How ? Seasprite 2004 - 2008 F150 44 02-15-2008 10:35 PM
Tags
08, 2006, 2008, 2011, 350, 4x4, diesel, f350, ford, gains, gallon, increase, methinol, miles, mpg, programmer, saves
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
