Tuner for 6.0
hey i have a 2005 6.0 F250 crew cab, ive been speaking to people and some people say DO NOT tune a 6.0 and others say DO IT, i just wanted some input from guys on here..... Which tuner to buy? if i disconnect /unplug the tuner will it go back to stock settings?
SCT tuner. I am going to tune mine with a tow tune when I can afford to get a tuner and a few custom tunes from eric. I dont think there is any problems at all tuning your truck as long as you are monitoring things so you know when to lay off of it for a bit. EGT get to high oil temps get to high and you just keep pushing it things can go wrong. But if you run a tune get a sct and a few custom tunes from innovative or gearhead. I think there are a couple more that people will recommend. Thats what im doing :)
i know some people are bad mouthing it but im running the banks 6 gun with the IQ dash pad tuner. it monitors all my peramiters so no need for any other gauges. i really like it and have not had any problems with it. it can shift tunes on the fly from stock to power level 6 and beyond that with the speedloader. but whatever tune you get i would definatly get something to moniter your EGT and boost pressure.
Sct tuner is a great way to go, you buy the tuner & custom files and load them into the trucks computer)pcm) You have to use the tuner return it to stock, with sct. You a basically reprogramming the pcm. I would do the tuner last, after the other mods. Once you tune your truck, it's nearly impossible to go back to stock.:-X04
Originally Posted by highteckredneck
(Post 11374112)
SCT tuner is the way to go. Because it tuners ur motor an also addresses the shifting of ur trans to. If u don't already have a exhaust kit I wood get it first then a scangauge to monitor motor then EGT an fuel pressure gauge before I got a tuner.
Those gauges will tell u all u need to know about how healthy ur motor is an what it's doing. |
I have a Edge Evo CS & i love it :-X22
Up to 100 extra HP when u want it, not to mention i can now monitor every engine function imaginable, i say go for it but use common sense.... You can program back to stock at any time, but remember to let the engine "breathe" a Performance Exhaust is a must & i put in a new intake as well the "blue spring" (for a little more Fuel Pressure) |
Originally Posted by zhilton
(Post 11378563)
What is that Banks doing to your transmission? I'm glad your watching the engine...but there's a transmission behind that flywheel that's taking a beating from an engine making more power than it was designed for. To each their own, but I think I'd do a little forum searching about slipping 5R110 and tuners.
about the same as any other tuner that changes the shift pressure in the transmission. its holding up fine, no slipping or anything. i really like the tuner myself cause im not a big fan of diesel blowing thick black smoke, i mean a little yea but all that smoke cant be good for your turbo, and thats what i like about the banks. |
i use a SCT TSX. I run matts tunes from gearhead. i love the SRL tune which is a street tune with power and also love the way functions the trans. i also have a tow tune from him as well. the shifting is great both up shifting and down shifting. i have towed some 5000 to 6000 lbs loads with no trailer brakes and feel confortable too. With the SRL, its a great daily driver tune which packs a punch when you need it. it only smokes when you want it to. be easy on the pedel and its better than stock. i put my truck back to stock a few weeks ago just for the hell of it. o man that only lasted for about 2 days. stock was such a dog. The TSX part of the tuner name is for Touch Screen Extrem. it is also a monitor. i have it set up to see my EGTs, Boost PSI, Battery Voltage, Trans Temp, Engine coolant temp and Engine oil temp all on the same screen. it was pricey when i got it. part of me says i wish i would have went with the sct x3 then got a scan gauge and i would have come out cheeper. also the scan gauge can show more info than my tsx. i just got a scangauge for my ranger and like having it in there.
like the other fellas have already said, make sure you can watch whats going on under the hood and between the frame. you can catch problems eairly and also know when you need to let the truck rest for a few. also this last statment may start some riots lol but after i done my exhaust and tune from matt i picked up 3 to 4 mpgs. but its very hard to keep your foot out of it. so most dont see the improvment. sorry for the long post but we fellow 6.0ers want you to be educated and armed with the right info incase you go to war with the 7.3ers which bad mouth the 6.0. Note: not all 7.3 owners bad mouth them. lol |
I also have the 6 gun and have a question for you. My code reader shows po611 ficm control module error. Do you think this is normal after installing the banks unit. (I'm thinking it is as banks is now controlling the fuel injection)
Originally Posted by vib1
(Post 11389229)
Yes, I cleared the code and it comes back again after the next start. Maybe I really do have a ficm problem then.
(Post 11389704)
you can check you FICM voltage and see if its bad. im sending mine out in the morning to ed@ficmrepair. my truck was running rought when frist started. i thought maybe it was my sct so i went back to stock and it still did it. then i started getting the same 611 code. checked my volts and was droping from 48 to 30 during first few minutes of starting.
(Post 11389229)
