Tuner for 6.0 - Ford Truck Enthusiasts Forums
Tuner for 6.0
Old 02-01-2012, 09:55 PM
Frankiea87 Frankiea87 is offline
Frankiea87 is starting off with a positive reputation.
Tuner for 6.0
hey i have a 2005 6.0 F250 crew cab, ive been speaking to people and some people say DO NOT tune a 6.0 and others say DO IT, i just wanted some input from guys on here..... Which tuner to buy? if i disconnect /unplug the tuner will it go back to stock settings?
Old 02-02-2012, 12:42 AM
dukie1877's Avatar
dukie1877 dukie1877 is offline
dukie1877 is gaining momentum as a positive member of FTE.dukie1877 is gaining momentum as a positive member of FTE.
SCT tuner. I am going to tune mine with a tow tune when I can afford to get a tuner and a few custom tunes from eric. I dont think there is any problems at all tuning your truck as long as you are monitoring things so you know when to lay off of it for a bit. EGT get to high oil temps get to high and you just keep pushing it things can go wrong. But if you run a tune get a sct and a few custom tunes from innovative or gearhead. I think there are a couple more that people will recommend. Thats what im doing
Old 02-02-2012, 06:19 AM
highteckredneck's Avatar
highteckredneck highteckredneck is offline
highteckredneck is gaining momentum as a positive member of FTE.
i know some people are bad mouthing it but im running the banks 6 gun with the IQ dash pad tuner. it monitors all my peramiters so no need for any other gauges. i really like it and have not had any problems with it. it can shift tunes on the fly from stock to power level 6 and beyond that with the speedloader. but whatever tune you get i would definatly get something to moniter your EGT and boost pressure.
Old 02-02-2012, 10:34 PM
Curt's05's Avatar
Curt's05 Curt's05 is online now
Wiser by FTE
Curt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud of
Sct tuner is a great way to go, you buy the tuner & custom files and load them into the trucks computer)pcm) You have to use the tuner return it to stock, with sct. You a basically reprogramming the pcm. I would do the tuner last, after the other mods. Once you tune your truck, it's nearly impossible to go back to stock.
Old 02-02-2012, 11:48 PM
zhilton's Avatar
zhilton zhilton is offline
zhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to allzhilton is a name known to all
Quote:
What is that Banks doing to your transmission? I'm glad your watching the engine...but there's a transmission behind that flywheel that's taking a beating from an engine making more power than it was designed for. To each their own, but I think I'd do a little forum searching about slipping 5R110 and tuners.
Old 02-03-2012, 02:33 AM
05 f250 6 inch lift's Avatar
05 f250 6 inch lift 05 f250 6 inch lift is offline
05 f250 6 inch lift is gaining momentum as a positive member of FTE.
SCT tuner is the way to go. Because it tuners ur motor an also addresses the shifting of ur trans to. If u don't already have a exhaust kit I wood get it first then a scangauge to monitor motor then EGT an fuel pressure gauge before I got a tuner.
Those gauges will tell u all u need to know about how healthy ur motor is an what it's doing.
Old 02-03-2012, 03:21 AM
King-bRanch's Avatar
King-bRanch King-bRanch is offline
King-bRanch has a brilliant futureKing-bRanch has a brilliant futureKing-bRanch has a brilliant futureKing-bRanch has a brilliant futureKing-bRanch has a brilliant futureKing-bRanch has a brilliant futureKing-bRanch has a brilliant futureKing-bRanch has a brilliant futureKing-bRanch has a brilliant futureKing-bRanch has a brilliant futureKing-bRanch has a brilliant future
I have a Edge Evo CS & i love it
Up to 100 extra HP when u want it, not to mention i can now monitor every engine function imaginable, i say go for it but use common sense....
You can program back to stock at any time, but remember to let the engine "breathe" a Performance Exhaust is a must & i put in a new intake as well the "blue spring" (for a little more Fuel Pressure)
Old 02-03-2012, 06:16 AM
Quote:
about the same as any other tuner that changes the shift pressure in the transmission. its holding up fine, no slipping or anything. i really like the tuner myself cause im not a big fan of diesel blowing thick black smoke, i mean a little yea but all that smoke cant be good for your turbo, and thats what i like about the banks.
Old 02-03-2012, 06:21 PM
goosehunta's Avatar
goosehunta goosehunta is offline
goosehunta is starting off with a positive reputation.
i use a SCT TSX. I run matts tunes from gearhead. i love the SRL tune which is a street tune with power and also love the way functions the trans. i also have a tow tune from him as well. the shifting is great both up shifting and down shifting. i have towed some 5000 to 6000 lbs loads with no trailer brakes and feel confortable too. With the SRL, its a great daily driver tune which packs a punch when you need it. it only smokes when you want it to. be easy on the pedel and its better than stock. i put my truck back to stock a few weeks ago just for the hell of it. o man that only lasted for about 2 days. stock was such a dog. The TSX part of the tuner name is for Touch Screen Extrem. it is also a monitor. i have it set up to see my EGTs, Boost PSI, Battery Voltage, Trans Temp, Engine coolant temp and Engine oil temp all on the same screen. it was pricey when i got it. part of me says i wish i would have went with the sct x3 then got a scan gauge and i would have come out cheeper. also the scan gauge can show more info than my tsx. i just got a scangauge for my ranger and like having it in there.
like the other fellas have already said, make sure you can watch whats going on under the hood and between the frame. you can catch problems eairly and also know when you need to let the truck rest for a few.
also this last statment may start some riots lol but after i done my exhaust and tune from matt i picked up 3 to 4 mpgs. but its very hard to keep your foot out of it. so most dont see the improvment.
sorry for the long post but we fellow 6.0ers want you to be educated and armed with the right info incase you go to war with the 7.3ers which bad mouth the 6.0.
Note: not all 7.3 owners bad mouth them. lol
Old 02-05-2012, 01:00 PM
vib1 vib1 is offline
vib1 is starting off with a positive reputation.
I also have the 6 gun and have a question for you. My code reader shows po611 ficm control module error. Do you think this is normal after installing the banks unit. (I'm thinking it is as banks is now controlling the fuel injection)
Old 02-05-2012, 02:57 PM
Quote:
have you cleared the code and see if it comes back? my banks throws no codes or had any problems with the ficm or anything
Old 02-05-2012, 03:09 PM
Yes, I cleared the code and it comes back again after the next start. Maybe I really do have a ficm problem then.
Old 02-05-2012, 04:23 PM
yes it sounds like you do have a problem with the FICM, but I don't think it because of tuner, you could unplug the tuner hook up the factory harness and then pull the codes but you would have to use another scanner
Old 02-05-2012, 08:49 PM
goosehunta's Avatar
you can check you FICM voltage and see if its bad. im sending mine out in the morning to ed@ficmrepair. my truck was running rought when frist started. i thought maybe it was my sct so i went back to stock and it still did it. then i started getting the same 611 code. checked my volts and was droping from 48 to 30 during first few minutes of starting.
Old 02-06-2012, 05:08 AM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
Your FICM is toast. Send it to FICM Repair.com - Your Source for FICM Repair and let Ed fix it before it leaves you stranded. Great company, prices, and customer service.
Tuners countrywill 1999 to 2016 Super Duty 9 09-28-2016 07:32 PM
Bully Dog tuner tcjhkbjt 6.0L Power Stroke Diesel 6 12-23-2013 11:32 AM
2006 6.0L Diablo Predator Tuner allingeneral Computer Chips & Tuners 8 05-05-2010 01:26 PM
Ppe tune for 6.0 ptr34 6.0L Power Stroke Diesel 27 07-12-2009 10:43 PM
Ppe Xcelerator Diesel Tuner tolie77 6.0L Power Stroke Diesel 6 12-10-2008 04:44 PM
Tags
60, banks, delete, egr, ficm, ford, iq, read, tuner, voltage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
