ranger rear end
Hi does anyone know if a ranger rear would fit into a 1948 f1 p/u?zLooking to swap out original rear with 427 gears to a ranger rear with 3.00-3.54 any help would be great,also if anyone has a rear with these gears that would fit this truck I will purchase it,thanks
dont know where you are at but up in phoenix there were a couple of places with rangers that har the rearends in them. I think they went for around $400.
Now what engine are you planning to use because if its a big one, I am not sure the ranger rearend will hold up. Might want to ask the guys that are doing v8 swaps what they are using. or go over to the ranger station and look/ask there. |
Thanks the truck is stock with 6cyl 4sp I just want a simple swap that will bolt right in
From what I remember, the mid 60's Bronco is the closest to fitting. Not sure how much fabricating needed to fit the Ranger.
Dave |
Originally Posted by train2
(Post 11360934)
swap rear
Hey thanks for all the info on the rear swap.I went to junk yard found a 72 f100 9 in. 5x5.Looked up the rear tag its 2.75 gears 9 in out of a 77 e-100,go figure,so here is another one that fits great ,no issues ,shocks mounted on 9 in rear stock,driveshaft bolt in,springs no problem,used 3in. hangers from junkyard,brakeline no issue,and the best part 69 mph,I can finally use first gear no issues,thank you for all your advice on this matter,I just put the old rear on craigslist,see what happens,thanks again
(Post 11421970)
48 f1
Hey thanks for reply you have a great day
