ranger rear end - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
ranger rear end
Old 01-30-2012, 04:33 PM
train2 train2 is offline
train2 is starting off with a positive reputation.
ranger rear end
Hi does anyone know if a ranger rear would fit into a 1948 f1 p/u?zLooking to swap out original rear with 427 gears to a ranger rear with 3.00-3.54 any help would be great,also if anyone has a rear with these gears that would fit this truck I will purchase it,thanks
Old 01-30-2012, 09:09 PM
Hank85713 Hank85713 is online now
Hank85713 is gaining momentum as a positive member of FTE.
dont know where you are at but up in phoenix there were a couple of places with rangers that har the rearends in them. I think they went for around $400.
Now what engine are you planning to use because if its a big one, I am not sure the ranger rearend will hold up. Might want to ask the guys that are doing v8 swaps what they are using. or go over to the ranger station and look/ask there.
Old 01-31-2012, 08:16 AM
Thanks the truck is stock with 6cyl 4sp I just want a simple swap that will bolt right in
Old 01-31-2012, 04:41 PM
smalltrucker's Avatar
smalltrucker smalltrucker is offline
smalltrucker is starting off with a positive reputation.
From what I remember, the mid 60's Bronco is the closest to fitting. Not sure how much fabricating needed to fit the Ranger.
Dave
Old 02-12-2012, 11:25 AM
jim collins jim collins is offline
jim collins has a good reputation on FTE.jim collins has a good reputation on FTE.jim collins has a good reputation on FTE.
Quote:
Don't know if you got this taken care of yet ,but the 9" rear from 72 and older F-100 , F-150 series will bolt in your 48 like it was made for it. It is the same width and stud bolt pattern, 5 on 5.5 , You will need to use the U-bolts made for the 9 " as it is larger in that area...... P.S It will handle a 460 engine with no problem.
Old 02-12-2012, 02:14 PM
Smile swap rear
Hey thanks for all the info on the rear swap.I went to junk yard found a 72 f100 9 in. 5x5.Looked up the rear tag its 2.75 gears 9 in out of a 77 e-100,go figure,so here is another one that fits great ,no issues ,shocks mounted on 9 in rear stock,driveshaft bolt in,springs no problem,used 3in. hangers from junkyard,brakeline no issue,and the best part 69 mph,I can finally use first gear no issues,thank you for all your advice on this matter,I just put the old rear on craigslist,see what happens,thanks again
Old 02-12-2012, 06:31 PM
Nothing wrong with the other rear,the 9" just fits better and is stronger. My 79 F-100 had the 9" and i had a 460 in it. Heavy foot caused it to burn up the tires to quick,L.O.L..........So I traded it for a 94 ranger.
Old 02-13-2012, 08:15 AM
48 f1
Hey thanks for reply you have a great day
ranger rear end widths wildstang Ranger & B-Series 15 05-17-2015 08:28 AM
Does the 3.55 performance axle really help performance? 1998Ranger25L153CID Ranger & B-Series 2 01-17-2015 12:58 PM
Anyone know of a good rebuild manual for Ford axles? Ranger Bob 2004 - 2008 F150 3 07-13-2014 05:59 AM
ranger crown vic ford truck jpmanyhearts Ranger & B-Series 0 05-27-2012 02:34 PM
rear end interchange loudfords Ranger & B-Series 2 03-21-2002 03:58 PM
Tags
9, end, fit, ford, in, mount, ranger, raptor, rear, rearend, stock, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
