Banks Transcommand + Punisher VB?? Lightning guys?
I just got my punisher VB from paul, and he told me that I probably don't need both. I already had bought the transcommand and I would still like to use it.
My specific application; '97 F250HD 460 + E4OD Have anyone seen any antagonism or negative effects of running the two together? I'm also looking for any info on using a 6 bolt TC with the 460+E4OD combo. I can't find any 6 bolt flex plates for the 460 in any year. |
Shifts might be a bit too hard for your liking possibly?
We did a trans-go shift-reprogramming kit on my friends truck, but we had to fine tune the shift pressures with the tuner to get it where he liked it. |
As mentioned above, you can change the TV pressure values for shift transitions, and that will help dial it in nicely.
I lowered the values under normal driving conditions, so the shift transitions or nice and easy. For heavy throttle conditions, I raised those values so it yields a nice snap for each shift. I've been running/abusing a Circle D converter for years now and no problems to speak of. It's a multi-disk lockup that is much stronger than stock with a 3000 stall speed (you can get them with a lower stall speed too). Their website doesn't have info for E4OD applications so it'd be best to call them. |
I have the Banks on my 94 lightning. It shifts hard and it takes some getting used to. but you stop noticing it after a while unless you have a lead foot :P
I'd try the valve body alone then add the banks if you want firmer shifts.
Definitely run the valvebody first. Mechanical is always better than a computer for Tranny upgrades. Also a firmer shift is actually better for the longevity of the transmission. Smooth shifts require a longer transition= heat =Bad for tranny. Jus sayin
