You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I just got my punisher VB from paul, and he told me that I probably don't need both. I already had bought the transcommand and I would still like to use it.
My specific application;
'97 F250HD
460 + E4OD
Have anyone seen any antagonism or negative effects of running the two together?
I'm also looking for any info on using a 6 bolt TC with the 460+E4OD combo.
I can't find any 6 bolt flex plates for the 460 in any year.
As mentioned above, you can change the TV pressure values for shift transitions, and that will help dial it in nicely.
I lowered the values under normal driving conditions, so the shift transitions or nice and easy. For heavy throttle conditions, I raised those values so it yields a nice snap for each shift.
I've been running/abusing a Circle D converter for years now and no problems to speak of. It's a multi-disk lockup that is much stronger than stock with a 3000 stall speed (you can get them with a lower stall speed too). Their website doesn't have info for E4OD applications so it'd be best to call them.
__________________
Matt C.
Intercooled Vortech, Victor Jr. heads, roller cam, 62lb injectors, 2800 stall converter, Eaton Locker, Pickrel Headers and Exhaust, FMS Mass Air using SCT tuning software. Road trip and dragstrip ready!
I have the Banks on my 94 lightning. It shifts hard and it takes some getting used to. but you stop noticing it after a while unless you have a lead foot :P
Definitely run the valvebody first. Mechanical is always better than a computer for Tranny upgrades. Also a firmer shift is actually better for the longevity of the transmission. Smooth shifts require a longer transition= heat =Bad for tranny. Jus sayin
